Author Topic: An Inch Away From Bliss - On The Stelvio  (Read 2475 times)
« on: May 16, 2016, 08:53:36 PM »
Thinking about a new Stelvio here but I am an inch too high in the low seat position to be happy.  Has anyone successfully taken an inch out of the Stelvio seat without too much loss of comfort?
« Last Edit: May 16, 2016, 09:17:43 PM by Dave Swanson »
Offline leafman60
Re: An Inch Away From Bliss - On The Stelvio
« Reply #1 on: May 16, 2016, 09:11:02 PM »
Thinking about a new Stelvio here and I am an inch too high in the low seat position to be happy.  Has anyone successfully taken an inch out of the Stelvio seat without too much loss of comfort?
I am not trying to be funny, Dave, but a Stelvio friend of mine with a similar problem took his boots to a shoe shop and they re-soled them with new lug soles almost an additional inch thicker.  They shimmed the soles!  He said it worked fine and made him look taller too!
He had to readjust his shift lever, though.
« Last Edit: May 16, 2016, 09:12:09 PM by leafman60 »
« Reply #2 on: May 16, 2016, 09:11:36 PM »
Don't feel too bad Dave Swanson, lots of blokes wish they had an extra inch and you've got one to give away !!!! Sheesh.....
Offline cwiseman
    • C&D Motorsports
« Reply #3 on: May 16, 2016, 10:34:22 PM »
Shave the front seat blocks down with a hack saw and it will lower the front of the seat a bit to make reaching the ground a bit easier.
618-544-RIDE
Offline Zoom Zoom
« Reply #4 on: May 17, 2016, 05:31:33 AM »
Just curious Chris, if you only shaved the front blocks, would that not tip the seat in a way that it would keep running you into the tank? Can the backs be shaved also, or is there a clearance issue there?
John Henry
Offline cwiseman
    • C&D Motorsports
« Reply #5 on: May 17, 2016, 07:17:38 AM »
My mind was backwards, thanks for catching that.
The rear needs shaved down to level out the seat, it helps keep you from sliding forward into the tank and makes it a bit easier to reach the ground.
618-544-RIDE
Offline Johncolleary
« Reply #6 on: May 17, 2016, 07:28:55 AM »
I had Rocky at Bill Mayer Saddles redo mine and it is lower and more comfortable than the stock seat.  I highly recommend him!!
2013 Stelvio NTX
2014 Triumph Tiger 800
2024 Honda Transalp
2023 Kawasaki KLX300
« Reply #7 on: May 17, 2016, 10:15:39 AM »
I've been riding a Tiger since '06, I got used to just putting one foot down early on, no biggie, your right foot should be on the brake pedal anyway. Touching with both feet is highly over rated. Most of the time I stop momentarily w/o taking a foot off the pegs anyway  *shrug*
« Last Edit: May 17, 2016, 10:16:28 AM by Guzzistajohn »
