Author Topic: Tygon anyone?  (Read 2624 times)
Offline drlapo
Tygon anyone?
« on: May 18, 2016, 07:56:12 AM »
Last year the urethane fuel lines on my BMW began to deteriorate.  I purchased many feet of ethanol resistant fuel line in many colors from an eBay shop.
I installed the new line on the BMW and an old Triumph.
The blue line looks good on the BMW and the red suits the triumph.
Yesterday the triumph developed a fuel leak about20 miles from home.
The fuel balance pipe between the carbs had split.  It was a piece of urethane tube.
I made a temporary repair using the reserve side fuel line.  That line is less than a year old and is hard and stiff.
My new ethanol proof colorful fuel line is crap.
I installed black fuel line from dayco that is clearly marked as fuel line.
The question is: if I want to use a smaller od line is tygon tubing suitable?
Offline RayB
Re: Tygon anyone?
« Reply #1 on: May 18, 2016, 08:09:39 AM »
I wouldn't use Tygon. I'd use quarter inch fuel injection hose from NAPA or such. It will fit ok under the breather box for the balance line too.
01 EV
82 BMW R100
Offline drlapo
Re: Tygon anyone?
« Reply #2 on: May 18, 2016, 08:17:54 AM »
Agreed, I'm using nitrile line now
Re: Tygon anyone?
« Reply #3 on: May 18, 2016, 08:37:43 AM »
I use Tygon hose from McMaster-Carr almost exclusively on all non-fuel injected bikes. I do not use it on BMW Airheads where the crossover goes through the engine/airbox casing though.
Offline mtiberio
    • TiberioRacing
Re: Tygon anyone?
« Reply #4 on: May 18, 2016, 08:44:22 AM »
the tygon from mcmaster carr needs to be the F4040 designation for fuel I believe. certainly regular surgical hose is NFG. Look for the fuel designation if using tygon.
I use it. gets hard and discolors over the years, but never hard enough to split or make it impossible to pull off (and put back on).
http://www.mcmaster.com/#tygon-f-4040-a-tubing/=12gprm1
« Last Edit: May 18, 2016, 08:45:00 AM by mtiberio »
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline bigbikerrick
Re: Tygon anyone?
« Reply #5 on: May 18, 2016, 03:00:26 PM »
I have been using the same yellow Tygon hose from McMaster Carr Charlie, and Mike recommend. Its good stuff, and easy to work with. I dont need to use any clamps with the Guzzi fittings.
Rick.
