Author Topic: Ducati 803 vs Guzzi 853 Power  (Read 4787 times)
Offline leafman60
« on: May 19, 2016, 08:54:31 AM »
I just received a spec sheet for the Ducati Scrambler engine.  Comparison with the latest Guzzi V9 is interesting. Both are air-cooled 90 degree twins, Guzzi has 50cc up on the Duc.
                              Ducati 803cc              Guzzi V9 853cc       BMW G650 Single          1972 R75          H-D 883
Horsepower       75 HP @ 8250 RPM       55 HP @ 6250 RPM       50 HP @ 6500         50 HP @ 6200          N/A
Torque              50 FP @  5750 RPM       46 FP @ 3000 RPM       44 FP @ 5000          43 FP @ 5000      54 FP @ 3750
« Last Edit: May 19, 2016, 07:16:38 PM by leafman60 »
Re: Ducati 803 vs Guzzi 853 Power
« Reply #1 on: May 19, 2016, 10:09:10 AM »
Just looking at them, it seems the Scrambler won't spend much time at the lower rpms, sort of contrary to its purpose. The Scrambler looks lime it wants to run just sitting there
They attract a lot of attention
Offline not-fishing
« Reply #2 on: May 19, 2016, 10:23:55 AM »
Why do I feel like it's Deja Vu all over again?
I keep thinking of the Stereo "maximum watts " output wars of the 70's
Or the cubic-inch car engine wars of the '60's.
On thing about the new Duc I do know is that 5 years from now there'll be a lot of used Ducs for sale with less 12,000 miles on them.  It's that little cost for  replacing the timing belts every two years that will convince some owners to sell them.
Now one Duc I'm happy to see is the Sixty-Two
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
« Reply #3 on: May 19, 2016, 10:55:29 AM »
That 803cc Ducati is going through shorter gearing to the rear wheel, and thus will deliver a lot more torque to the road.  Plus the shaft-driven Guzzi will have more drive line losses than the Duc.
That isn't to say that the V9 engine won't be an enjoyable engine.   I have the Monster 796, which has an earlier version the 803cc engine tuned for even more power (less constrained by emissions), and, of course, two V7's, which make even less power an torque than the V9 engine.    I truly enjoy my V7's as much as I do the Monster, for different types of riding.
It isn't just about the numbers.
« Reply #4 on: May 19, 2016, 10:58:38 AM »
Ducati Cam Belt Replacement April 2015 - YouTube
http://m.youtube.com/watch?v=pAhwVlITOKI
In case you want to see how it's done.
« Last Edit: May 19, 2016, 11:01:48 AM by Norge Pilot »
« Reply #5 on: May 19, 2016, 11:13:32 AM »
This is all you need to know about the personality of the engines:
Peak torque at 3,000 rpm will make for a more tractable engine.  If tractable is what you're wanting...
Offline leafman60
« Reply #6 on: May 19, 2016, 12:10:53 PM »
I'm wondering, IF GUZZI WANTED TO make a sportier bike with the V9, why they couldn't retune the motor with cam profiles etc to produce nearer to the power of the Ducati engine?
I realize the valve train is different etc but, if Ducati can get that sort of power from a smaller motor, why can't Guzzi get closer to it with the V9?
« Reply #7 on: May 19, 2016, 12:17:26 PM »
http://www.motorcycle.com/shoot-outs/scrambler-slam-ducati-vs-triumph/attachment/031915-2015-ducati-scrambler-vs-triumph-scrambler-hp-torque-dyno
A little more perspective of the Scramblers torque curve.
390+ pounds, a pretty light bike. Different bike too.
« Last Edit: May 19, 2016, 12:18:48 PM by Norge Pilot »
« Reply #8 on: May 19, 2016, 12:28:25 PM »
 There might in fact be a couple of Shetlands lurking in the V9 engine that have gone untapped . However we are talking different markets and designs here . Just like HD has stuck to an older design that gives up a few ponies to the design used by Polaris . Company culture at work .
« Reply #9 on: May 19, 2016, 02:11:44 PM »
Maybe they aren't done with the v9. Just a thought.
Offline Vagrant
« Reply #10 on: May 19, 2016, 02:20:57 PM »
and it's all good until you are going uphill at 8000 feet with a ford dually pulling a horse trailer belching un burnt diesel all over you. then it sucks!
« Reply #11 on: May 19, 2016, 02:28:44 PM »
Horse trailer?  Could be worse than black smoke...  LOL!
« Reply #12 on: May 19, 2016, 02:43:52 PM »
That is precisely why I ride the Monster on the mountain rides where it does uphill passes much more quickly than the V7's do.
Sure, the Guzzi torque comes in lower, but, the higher end power of the Duc is only a shift or two away for lickity-split passes, even up hill behind a diesel rolling coal.
« Reply #13 on: May 19, 2016, 03:24:50 PM »
 Misread that as someone was trying to pull a horse trailer WITH a motorbike  :shocked:
 "Well heck , we wassah doin' pretty good until it came time ta stop , then things got real interestin' "
« Reply #14 on: May 19, 2016, 03:34:12 PM »
There are some things I don't follow close.  And it's not because of diesel smoke!
Offline lucky phil
« Reply #15 on: May 19, 2016, 05:12:26 PM »
Ha, who the hell changes cam belts every 2 years, not me. Currently have 3 belt drive Ducatis in the fleet and have owned and worked on many more and have never bothered with this silly requirement. Never had one fail and my bikes do track work as well.
Ciao
