Author Topic: NGC - Lost My Screwdriver While Changing Sparkplugs  (Read 8617 times)
Re: NGC - Lost My Screwdriver While Changing Sparkplugs
« Reply #30 on: May 24, 2016, 10:36:30 AM »
Found a nice pair of Channel locks (which I still have.. anybody stupid enough to leave tools in an engine compartment deserves to lose them)  :evil: Found a crowbar (!!) under the hood of my Chevette. Don't have that one, I gave it to the owner of the business.
« Reply #31 on: May 24, 2016, 10:41:22 AM »
 Probably needed the leverage to work the clutch  :shocked: :laugh:
« Reply #32 on: May 24, 2016, 10:47:38 AM »
I found a beautiful one-off wrench still on the bolt head in my Mercedes engine compartment.
Still have the wrench and Mercedes too. I went back and asked in an open ended way if the "tech" was missing a wrench and if so, could he identify it. In a CYA move, no one fessed up. Due diligence bowed to, I have a specialty wrench.
Todd.
Offline jbell
  • Some progress
« Reply #33 on: May 24, 2016, 03:51:32 PM »
Jbell,
I bought the car recently with 109k miles.  The plugs look like they've got about 50k miles on them.  The gaskets looked ok, but I added a little Hylomar to the seals.   As for the "T" pipe that sends coolant to warm the throttle body (TB), did you know there's a modification to eliminate that?
An interesting design idea; do you want a heated TB, or a cool one?
No, I didn't know about the modification but will consider it in about 80,000 more miles or so.   :laugh:
'76 Guzzi T3   Future project
'78 Guzzi G5  Current project
'81 Guzzi G5  Organ donor
'92 BMW K75RT  On the road
« Reply #34 on: May 24, 2016, 08:08:37 PM »
Our little aircraft all have carb heat.  On the old VWs 'icing' was a physical problem -- the car would stop and if you ran around back and raised the hood fast enough you could see a little gasoline icicle melting off the butterfly shaft.
« Reply #35 on: May 24, 2016, 08:12:49 PM »
Would that be a gascycle?
Offline sign216
« Reply #36 on: May 24, 2016, 08:28:20 PM »
That is to keep ice from forming in the intake, at least that's the idea. Common problem with normally asperatied piston engines but usually not a problem with fuel injected right above the intake valve.
Ok, thanks.  I was thinking under the older idea of "cool intake air is the best."
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline sign216
« Reply #37 on: May 25, 2016, 08:34:07 PM »
So I took my car out today.  It was hot, and when I put on the air conditioning I got an unhealthy growl.
The compressor is in the area I lost the screwdriver, but I still can't see it.
The car's going into the mechanics on Friday.
This screwdriver might be expensive.
Such is the price of doing your own repairs, eh?
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline Rotten Ralph
« Reply #38 on: May 26, 2016, 09:45:26 AM »
Every time I think about starting a project I try to weigh the savings versus the cost of having someone who knows what they are doing do it. Seems like more often than not doing it myself saves money but takes up hours of my time, gets me frustrated, and often has me buying or ruining a tool. But aaahhhhhh the satisfaction!. :wink:
Never trust a dog to guard your food
03 HD RK / TLE car
65 BMW R69S
60 BSA Gold Star
13 Moto Guzzi V7 Special
« Reply #39 on: May 26, 2016, 12:36:53 PM »
Tools, in the right hands, are consumables.
 :grin:
