Looks like you're working on an 850T like mine. The shocks on mine (Ikon) are about 20mm longer than stock just like yours. They were on the bike when I bought it in 2004. They work fine. However, my muffler will just contact the axle nut on full extension and both wheels will just touch the ground when the centerstand is down - plus the extra 1/2" height makes the sidestand precarious at best to use - not a big loss on these anyhow! I have been considering replacing them with the correct length now that they are available again from MG Cycle. Lifting the rear end up does quicken the steering (a little). Pros and cons...
