Author Topic: 2013 V7 Clickiness  (Read 9618 times)
invisibro
Re: 2013 V7 Clickiness
« Reply #30 on: May 26, 2016, 08:40:21 PM »
So, how did it go?
Great! No major issues.
Jim and crew are all really nice, and Jim knew a few things to look for in my model year that could have caused trouble down the line - specifically the plastic part of the fuel pump that was indeed already weakened by ethanol and the voltage regulator which was overcharging my battery.
Valves did need adjusting but weren't too bad. And the clutch cable def needed rerouting.
Oh and got the updated ECU map!
invisibro
« Reply #31 on: May 26, 2016, 08:42:37 PM »
Thanks again for the suggestion and advice all!
Now to recover from new York highways and stock guzzi v7 suspension
« Reply #32 on: May 26, 2016, 08:45:36 PM »
 Good news  :thumb:
Offline johnr
« Reply #33 on: May 26, 2016, 11:41:52 PM »
There you go!  :thumb:
Did you get to watch and learn?
« Last Edit: May 26, 2016, 11:42:48 PM by johnr »
New Zealand
Offline gerryp
« Reply #34 on: May 27, 2016, 01:52:11 AM »
Great to hear you had a good experience.  For me dealing with Jim & his staff is well worth the two hour ride up to his shop.
Gerry
invisibro
« Reply #35 on: May 27, 2016, 06:53:32 AM »
I had to work remotely from his comfy waiting room most of the day, but he called me down a few times to watch. He showed me how to feel the proper tightness on the valve adjustment. Very easy, but also very easy to mess up
« Reply #36 on: May 27, 2016, 07:18:33 AM »
Great result!  This is an example of WG at it's best!
