Author Topic: An important tip if you're buying a used...but fairly new...Moto Guzzi  (Read 5127 times)
Offline SLDMRossi
Before you complete the deal verify that it has two keys. If there's only one, knock $100 off the price!
Because if you order a replacement from Piaggio, the cost is going to be on the order of $90. One reason is because when you order "Quantity 1," you end up getting "2" blanks. Then, you have to take them to a Locksmith and get them cut...or in fact, milled.
Steven Rossi
East Haddam, CT
Offline Bud
I'm guessing the sport came with "1" key?
Offline SLDMRossi
You got it...and oh by the way, if it's only got "1" key...it probably doesn't have an Owner's Manual, either. But at least that you can source off of e-Bay...for a price.
SR
Offline not-fishing
I was happy to get two keys for $100, being one of the older fellas I tend to misplace my keys - often.
Maybe it's a side effect of my Five-Mississippi's of Medicine.
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
Motorcycle key tip:  Never put them anywhere other than in the bike's ignition switch or the pocket of your riding pants.
Offline Bud
     The bike is SWEET, could be much worse!
Offline SLDMRossi
Rode it to the Locksmith...can't do better than that!
SR
Offline sib
Although my recent V7 came with 2 keys, I had my local locksmith cut a couple of spares, using generic blanks, for about $3 each.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline SLDMRossi
Generic blanks for a milled key?
SR
Offline johnr
Got a spare made at a local locksmith for a fraction of that ($100) price?? Just a few bucks from memory.
« Last Edit: May 28, 2016, 09:41:53 AM by johnr »
New Zealand
Online blackcat
I had a key made for the Norge and I believe it was $45 including the key.
Offline Waltr
    • Europa Macchina
Very late model Guzzi's  could be chipped and require knowing the CODE to allow the new key to be programmed to the bike.  If someone along the way has set the code other than all zero's and that code can not be accessed you may end up buying a complete instrument cluster just to be able program additional keys.
                            BE VERY CAUTIOUS BUYING BIKES WITH ONE KEY AND NO KNOW CODE
www.motoguzzipa.com
2012 Norge
Isn't there a way to clone a key cheaply, like my  Ford Taurus can do?
lucydad
Huh, on a related note:  three of four Porsche Caymans I checked out only had one key.  Dealers could not figure out why I was not happy with that given replacement cost of $300 for key and programming.  Individual just shrugged his shoulders.  Walked away -- missing key was a key factor...
Yes. The cost depends on where you get it done. If Moto Guzzi figured out a way to prevent the codes from being read or the keys from being cloned the FBI and Apple sure would like to talk to them about it.
Even with immobilizer technology, the keys can be cloned and the codes can be read. No, you don't need a new dash.
My Taurus will do it for me if I have a new chip type key that has been cut but not programmed.  There's a cryptic procedure that has you turn the ignition on and off, insert the original key and then insert the new one (etc) and when you're done, the new key is programmed like the original one.  I was wondering if Guzzis have a similar procedure to let the owner copy a key.
Not like that.
Those keys like you're talking about often let you change other options like the chirp when the alarm is set and so on.
