Author Topic: Mille shock mount?  (Read 1908 times)
Offline Testarossa
    • Skiing History
Mille shock mount?
« on: May 30, 2016, 11:28:57 AM »
Please help -- I'm stumped. How to withdraw this stud to remove the shock, not to mention the grab bar?
Offline analog kid
Re: Mille shock mount?
« Reply #1 on: May 30, 2016, 12:13:16 PM »
on mine it's an Allen head bolt running through the grab bar, shock, then threads into the frame.
Looks like someone installed a chrome cap in the screw head. Pop it out with a flat blade screwdriver and you should be good to go.
the grab bar is also secured  with bolts running from inside the tailpiece, through the bodywork and threading into the bar. There's a plastic toolbox you remove for inside tailpiece access.
90 Mille GT
03 Aprilia Caponord
84 LeMans lll (project)
07 Breva 1100 (sold)
« Reply #2 on: May 30, 2016, 12:16:27 PM »
Those little caps were standard for Guzzi back then, and I believe there is a part number if you're so inclined to replace it with a new one.  :wink:
Offline pehayes
« Reply #3 on: May 30, 2016, 12:33:31 PM »
When I first saw your pic I thought it was a snapped off hex.  Other comments are likely that it just has a cosmetic cap.  I did a quick Google for 'Allen bolt cover'.  You likely have something like this which just pries out with a screwdriver or knife blade.
Offline Testarossa
    • Skiing History
« Reply #4 on: May 30, 2016, 02:52:55 PM »
Thanks! Fancy pannier rack going on.
« Reply #5 on: May 30, 2016, 03:51:52 PM »
You can buy little caps that will fit in the allen head bolts from ACE Hardware.  I bought some for the Strada.  So as mentioned, pry out then use an allen wrench for the rest.
Offline analog kid
« Reply #6 on: May 31, 2016, 11:17:04 AM »
Whoops! Screwed that one up, sorry. Forgot that the bolt passes through the grab bar, then threads into the shock mount, not the frame.  :boozing:
90 Mille GT
03 Aprilia Caponord
