Author Topic: Pre-seasoned cast iron skillets  (Read 7929 times)
Re: Pre-seasoned cast iron skillets
« Reply #30 on: June 01, 2016, 10:32:45 PM »
I gotta work on re-seasoning mine.   :thumb: :thumb:  I gotta break out the propane torch.
Offline Farmer Dan
« Reply #31 on: June 01, 2016, 10:33:39 PM »
I put my cast iron pans in a camp fire, let them turn red them pull them to the edge so they cool slowly.  Next day take it in the house scrub the ash off with a wire brush and season it by cooking a pound of bacon and smearing the grease around.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
« Reply #32 on: June 01, 2016, 10:41:19 PM »
I like the bacon method because of the smell.
Online AJ Huff
« Reply #33 on: June 01, 2016, 11:17:50 PM »
As an iron foundry metallurgist, this thread is very painful.
If for some reason you want to remove your seasoning, and there really is no good reason for you to do it, just run it through the dishwasher.
As to the pre-seasoning that Lodge supplies, most of what you read on the internet is utter BS. There's no reason to doubt it's quality.
As to seasoning your pan yourself, there is plenty of voodoo written on the subject. I have a stack of pans and my method is basically just cook bacon, again and again and again. Of all the mumbo jumbo out there, it is the easiest and most fool proof method. Tried and true. bacon.
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
Offline Yukonica
« Reply #34 on: June 01, 2016, 11:52:29 PM »
That's a hard core purification of the metal. Bet it takes the seasoning like a sponge does water.
Have you experienced any crystallization of the casting?
Offline Perazzimx14
« Reply #35 on: June 02, 2016, 06:01:53 AM »
-AJ
Ever buy vintage CI at a yard sale or flea market? Not knowing what other people did with the CI prior to me getting it is more than reason enough to strip and re-season.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline Aaron D.
« Reply #36 on: June 02, 2016, 06:06:13 AM »
Having used cast iron cookware most of my life I never knew there could be so much discussion on seasoning!
I clean our pans with a stainless chin-mail thing. We never thought about the concept that the vegetable oil that Lodge used might be somehow...lacking.
But don't listen to me. I cooked venison on a shovel once.
Offline Ighani
« Reply #37 on: June 02, 2016, 08:13:33 AM »
With "pre-seasoned" pans, it's a hose clamp still necessary?
Offline alienbogey
« Reply #38 on: June 02, 2016, 08:23:06 AM »
Check out the CI pans made by Finex in Portland, Oregon USA.
They got going via Kickstarter fairly recently and their pans are marvelous.
Moto Guzzi.  (<<< to keep on forum topic)
Offline donn
« Reply #39 on: June 02, 2016, 09:01:47 AM »
I have a vague memory that I cleaned a pan down, maybe even twice until I got it done right.  I bought the pan from the hardware store in my youth, and put it in the oven and baked gobs of vegetable oil onto it, resulting in a scabby mess.  I have never had oven cleaner around at any time in my life, I reckon I probably used lye (dissolved in water of course.)  You have to heat lye for it to be really effective, so it isn't very convenient, but you know what's in it.  If hot lye isn't so much of an option, I suppose it would still work, just takes longer.
The main thing I don't use cast iron (or seasoned wok) for is when there's a tomato sauce, I have a hunch that's hard on them.
Offline Nic in Western NYS
« Reply #40 on: June 02, 2016, 09:29:55 AM »
Regularly use CI for gnocchi with tomato sauce, no harm but you can tell the seasoning needs refreshing after a scrubbing. A little cooking oil rubbed in and enough heat to gently smoke it off and good as new.
'04 Ducati ST4sABS
Offline yogidozer
« Reply #41 on: June 02, 2016, 09:56:10 AM »
Frying pans????
OK, do you use synthetic or mineral based oils?  :boozing:
Offline ken farr
« Reply #42 on: June 02, 2016, 11:25:48 AM »
-AJ
How dare you interject experience, knowledge and common sense into a thread ?? :thewife:
For shame......... :bow:
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Fuzzy
« Reply #43 on: June 02, 2016, 11:58:29 AM »
After reading the thread I made myself some bacon. A buddy makes it at home and it is special. He makes pancetta too.
We've got both Lodge and Griswald. Obviously the Griswald is nicer since it is much older and has been cared for. Was my in-laws. The Lodge is coming around though. Rough at first, but you can see the possibilities pretty quick. They make great family heirlooms.
« Reply #44 on: June 02, 2016, 10:37:22 PM »
I still miss my egg pan from 30 yrs. ago.  Wish I hadn't given it away before I moved.
