Do you mean when you let go of the throttle grip, it doesn't snap closed with authority?If so, the first place I'd check is on the handlebar. Grip interference with switch housing or bar end. Dirt/grime between the throttle tube and and handlebar. Etc...
I rode through a ton of rain yesterday and now the throttle isn't closing with the kind of certainty I'd like.I sprayed some WD40 on the springs under each throttle body and snugged up the rearward adjuster at the housing but am wary of why it became loose.
