Author Topic: New auxiliary lights on the Norge  (Read 4400 times)
Offline ITSec
« on: June 07, 2016, 06:54:12 PM »
While there were some old threads on this, they're pretty old - so I thought I'd just start a new one.
For all my long-distance riding on the Norge, I've never added driving lights till now. However, I found a pair of lights on eBay that were too good a deal to pass up - 30-degree spread, quality CREE LED sources, a two-year warranty, good reviews and only $25 (red suspender content). I probably spent that much again in creating a mount for them, but the result was worth it. They are much brighter than the stock lights (which are among the best factory lights in the business); the spread is similar to the low beams, the reach is about 25% further than the high beams. Using a count test in a remote rural area, I was seeing things roughly 35-40 seconds before I reached them at 70 mph - that's roughly 5/8 of a mile, or a full kilometer.
I used an aluminum L-channel, about 20 inches long, and mounted it to the bottom of the fairing using 8mm machine screws, large washers and nylock nuts. I considered using a backing plate inside the fairing, but it was just too difficult to place it under the fairing rail.
Here's some photos:
One of the lights with its mounting parts (included):
The aluminum bracket, drilled on my drill press, prior to paint:
Lights and mount (post Ironbutt ride with freshly installed bug guts):
Lit up with high beams:
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Online PJPR01
Re: New auxiliary lights on the Norge
« Reply #1 on: June 07, 2016, 07:54:46 PM »
Fantastic!  Any night time pics as well to share?
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Online steven c
« Reply #2 on: June 07, 2016, 08:07:10 PM »
 Those look nice. Have a link to the EBAY site?
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline JeffOlson
« Reply #3 on: June 07, 2016, 08:25:14 PM »
Very nice!
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
Offline ITSec
« Reply #4 on: June 07, 2016, 08:31:27 PM »
Night pics to come - couldn't stop for them while on the IBA ride.
ITSecurity
Offline ITSec
« Reply #5 on: June 07, 2016, 08:35:00 PM »
Actually, it was Amazon I ended up buying through, since they have a better return policy. See http://www.amazon.com/Nilight-Driving-Mounting-Bracket-Warranty/dp/B00G620ZVU?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
ITSecurity
« Reply #6 on: June 07, 2016, 08:40:50 PM »
That looks mighty good!   :thumb:
Offline pressureangle
« Reply #7 on: June 07, 2016, 10:43:13 PM »
Sweet! You can never have too much headlight.
Offline ITSec
« Reply #8 on: October 14, 2017, 02:34:18 AM »
Just to refresh this topic, the price for these lights has now dropped to less than $15 a pair. The listing no longer mentions CREE LEDs, but at that price they may still be a good buy.
ITSecurity
Offline bettythebear
« Reply #9 on: October 14, 2017, 10:03:13 AM »
Any interest in fabbing up the bars?
2011 v7 Classic
Offline ITSec
« Reply #10 on: October 14, 2017, 01:25:12 PM »
It's really pretty simple - your local Lowe's or Home Depot can sell you a 24" piece of 1" aluminum L channel extrusion. Cut it to 20" and use this template to guide your work. http://people.delphiforums.com/ITSecurity/Norge/LightBarNorgev0-1.pdf
Use a rotary tool with a couple of metal cutting disks (you'll go through a couple), if you want holes just tape the template sections onto the metal and drill as indicated using a wood block behind the channel. A drill press is much better than a hand drill for this as you can be much more consistent and get a professional looking result. After cutting and any drilling, use a grinding stone on the rotary tool to do a quick dress-up of the edges and ensure no sharp scrap or corners exist. Then spray paint using a combined primer/paint - I used Krylon's low gloss black designed for metal including aluminum.
ITSecurity
Offline wymple
« Last Edit: October 14, 2017, 03:08:37 PM by wymple »
Offline wymple
« Reply #12 on: October 18, 2017, 11:03:24 PM »
So, I ordered a pair of these from fleabay, 16.99 shipped, and they arrived today. Tonight I went out and hooked one up to my truck battery and I must say they are brighter than any other low priced driving lights I've spent money on, and by far. I'm pretty impressed.
