Author Topic: Welding . flux core or Mig ?  (Read 14432 times)
Re: Welding . flux core or Mig ?
« Reply #60 on: June 14, 2016, 08:02:55 AM »
Walking the cup is just a technique I mentioned after you brought up difficulty in keeping the tungsten out of the puddle.  I don't normally use it.  For long, straight welds on tricky material, specifically when I'm welding 2-stroke expansion chamber seams (20 ga. mild steel or 22 ga. stainless), I use a guide I made that clamps to the side of my welding table and supports my torch hand, letting me slide it along the guide.  It's a fusion weld, so I can steady the torch with my other hand too.  It takes the shakiness away so I can make a pretty weld.
As you said, you can rig up whatever it takes for the job.  There isn't one technique for everything.
Rough Edge racing
« Reply #61 on: June 14, 2016, 08:40:22 AM »
 I often MIG weld with two hands on smaller stuff for better accuracy...  My latest LSR bike frame is ready for finish welding so I'll try the TIG on it...
Offline Motu
« Reply #62 on: June 15, 2016, 04:50:02 AM »
I use CO2 for my MIG at home, much cheaper than an argo mix.  I got an alloy dive tank for nothing, had it retested and filled. I can't afford a shield gas tank, but you can use dive bottles, even fire extinguisher tanks for CO2.  I've been repairing a rusty JD mower deck at home, the CO2 has been working just fine.
