Author Topic: LeMans One question... switch gear  (Read 2608 times)
Offline Cal3Me
« on: June 12, 2016, 02:36:59 PM »
I need help with removing the clutch side switch gear & wiring on a Lemans 1 to replace the broken clutch lever bracket. Tips & tricks please  :boozing:
TMS
Re: LeMans One question... switch gear
« Reply #1 on: June 12, 2016, 03:43:52 PM »
If you are changing the perch it must be a rotating sw like on a T.   Unplug pin conn out of Molex going to sw.  They usually feed in & out a hole in bar or clip-on. Silicone spray & patience.
If you can't do it, take it to Joe.
« Last Edit: June 12, 2016, 03:45:12 PM by guzzisteve »
Offline Cal3Me
« Reply #2 on: June 13, 2016, 01:42:33 AM »
Yep.... it's like a T-bike. Sliding the wires out far enough to get to the end of the clip-on looks like the hard part? Removing the wires from the molex and pulling them out of the clip-on...huh? Nothing is easy .. :undecided:
Thanks buddy  :thumb:
TMS
Offline Carlo DeSantis
« Reply #3 on: June 13, 2016, 03:37:59 AM »
Tim,
There's a removal tool that makes it easy to get the leads out of the Molex connector.  I have one if you want to borrow.
Best,
Chuck
Chuck in Illinois
Crystal Lake, IL USA
'75 850 T3 Custom
'11 R1200R
Offline Cal3Me
« Reply #4 on: June 14, 2016, 11:58:16 PM »
chuck...... I found a funny looking tool in a box of mine and was told it's a Molex tool. There are 4 different size sleeves on it that slide over the pins. Thanks for the offer ,, :thumb:
TMS
Offline leafman60
« Reply #5 on: June 15, 2016, 08:23:11 AM »
As a side note, if you don't have the official molex tool, you can improvise one with some brass tubing from a hobby store.
Select the size that just slips over the pins or sleeves.  You can slightly crimp the end of the tube if you need more squeeze on the lock tabs.
Offline Two Checks
« Reply #6 on: June 15, 2016, 09:27:59 AM »
Beware the locking tabs on the pins can and do break off when extracting them.
1987 1000 SPII "Il Duce' II"
« Reply #7 on: June 15, 2016, 06:03:32 PM »
Identical clip-ons and switches on the 750 S3, I removed the connector block end first, then pulled off the plastic sheathing, slowly pushed the wires up and out through the bars.
I recommend buying new PVC sheathing and spritz some glass cleaner or dish detergent / water into the PVC and then push the wires through. MG Cycle sells new rubber boots that cap the end of the clip-ons as well.
The switches are delicate and it's a good time to get some brake cleaner and wash them out. I cleaned up the brass parts inside the switch with a fine file and brass brush then some electrical grease.
The head light switch locks into a recess in the clutch perch and the switch into a recess in the light switch.
