I offer via a lot of miles on Guzzis, that if 95% or better of your riding is done on solid pavement, linked brakes have all the advantage. If you have a long, sloping, hardscrabble driveway, run the unpaved alphabets a lot or regularly encounter unimproved or damaged roads, unlinking may have an advantage. There are times off-pavement when you need to drag the rear wheel while letting the front wheel spin free, and linked brakes can't do that. That's the only linked brake tradeoff I can think of.
Dukedesmo, Stevex,What front calipers do you have? I'm thinking about de-linking my 04 Cali EVT and I have the 4 piston Brembo gold. I'm trying to figure out if I need a 15mm or 16mm master cylinder. On MG the 15mm was suggested, but I'm not clear for which calipers.Why do I want to de-link: Two incidents. One was just about dumping the bike in a mall type parking lot at about 10mph or less in a bit of a panic type stop while I was still leaned over a bit from a turn. The other was when a car wanted to make a right turn in front of me. Did I mention I was in the right lane and he was in the left. Well I hit the rear brake and both wheels locked up. Fortunately this was at about 15-20mph and in a straight line.I'm a bit afraid of a panic stop on the freeway in the wet at 60mph in a curve and the front dumping on me. If one brake is going lock I'd rather it be the rear.The problem could be just muscle memory from riding drum brakes for the last 30+ years. I really want/wanted to like the linked brakes! For the most part they are fine.Tom
You can use them exactly like unlinked brakes on pavement if you want to -- handbrake primary and footbrake to trim or add emphesis. Or you can do the opposite -- footbrake for normal, already trimmed braking, and add handbrake as needed for more emphasis. People say linked brakes are dangerous and different. They're not. What's dangerous is thinking about them too much. What's different is that the footbrake is umpteen times more powerful than a standard rear pedal because it's working both axles, leading some (as commented above) to get complacent and not use the handbrake.Next time you're at a rally look at front brake pad wear on linked bikes -- the left pad is almost always worn down more. In fact with linked brakes it's often possible to buy one pair of pads, put them in the right side, and rotate the right side pads to the left.I offer via a lot of miles on Guzzis, that if 95% or better of your riding is done on solid pavement, linked brakes have all the advantage. If you have a long, sloping, hardscrabble driveway, run the unpaved alphabets a lot or regularly encounter unimproved or damaged roads, unlinking may have an advantage. There are times off-pavement when you need to drag the rear wheel while letting the front wheel spin free, and linked brakes can't do that. That's the only linked brake tradeoff I can think of.
What I do now is use a LOT of engine braking, but, it is not very smooth unless slipping the clutch a lot.
Not telling you what to do, but I avoid engine braking because a clutch is not a fun thing to replace. Brake pads are easy and cheap to replace.
Well if you're riding a sidecar or a cruiser/dedicated touring bike then yes. But on anything approaching a sports bike linked brakes are an abomination.Ciao
This is nonsense. At least one national championship was won by Dr. John's linked-brake Guzzi racer. All three brakes were linked into a single system. (Oh, my!)Moto
