Author Topic: Any ideas what is leaking?  (Read 2841 times)
Offline CapitalGoose
« on: June 14, 2016, 12:42:54 PM »
Hey gents,
I noticed this on my bike the other day. I think the breather valve is leaking. Took it in for the dealer to check out but apparently it may take more than a week for them  to get back to me. *sigh* What do y'all do if your still-under-warranty bike has a problem that is easily addressed? Do you fix it or take it into the dealer (and wait forever to get it back)?
All the best,
CG
Offline twhitaker
Re: Any ideas what is leaking?
« Reply #1 on: June 14, 2016, 12:58:15 PM »
That's a breather and breathers have been known to...
breathe.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
« Reply #2 on: June 14, 2016, 12:59:18 PM »
Ride it.  Seriously.
That's just some mist from the transmission vent.
I would check the level of the transmission oil.  It may be over-full.
Then, I would ride.
No, I wouldn't waste my valuable time screwing with a dealer over something like this on MY bike.
No, I would not take my bike to a dealer who tells me there is a one-week wait time to look at something this simple.
Ride it.
« Reply #3 on: June 14, 2016, 02:50:20 PM »
On the older SB's we would put a barbed fitting there and a hose going up w/pcv valve on the end under the tank. Then it goes up a hose and doesn't spew out.
Offline jmac851
« Reply #4 on: June 14, 2016, 04:38:11 PM »
Carry a rag to wipe it off if it bothers you that much.
1967 V700
1969 Ambassador
1984 Cal 2
1996 Cal 1100
1998 EV 1100
2006 Breva 1100
1994 BMW R1100RS
« Reply #5 on: June 14, 2016, 04:49:58 PM »
Gearbox is probably over filled. The smallblock six speeds are reluctant to drain as I found out when I did the first service on Craig's bike. For whatever reason I didn't get all the oil out and because there is no level plug I simply added 1/2 a litre of new oil. It ended up with far too much in and spewed it out of the vent with considerable vigour!
Drain it overnight with the filler cap off and remove the gauze filter from under the drain plug. In the morning reinstall the filter and drain plug, fill with an accurately measured 500ml of gear oil, reinstall filler plug, go ride.
Red Dog
« Reply #6 on: June 14, 2016, 05:07:21 PM »
Ride captain ride upon your mystery ship
That lil bit of oil won't make you slip
Offline jackson
« Reply #7 on: June 14, 2016, 06:47:59 PM »
THIS.............has a 99.99999% probability of causing your particular problem.  Someone else posted the exact problem on this board a couple of weeks ago...............a nd Pete works on Guzzis every day for a living so he knows what he's talking about.
NO longer can ride
« Reply #8 on: June 15, 2016, 10:39:33 AM »
Whew. Thanks fellas! Esp Pete!
Man, I love you guys!
