Author Topic: Oil filter weirdness, Griso edition  (Read 1615 times)
Offline guzziownr
« on: June 15, 2016, 07:03:20 PM »
With a free quart of oil courtesy of Amazon I wandered out to the garage to effect an oil change.  Last Fall I dropped the pan on the SP engined '75 Eldo and complained on this forum that they had changed the UFI filters from 8 flats to 12 making my fancy Stucchi filter wrench obsolete.
I was mocked! Mocked in this forum as a corncob chewing, suspender-snapping dinosaur with decades-old filters on my shelf.  A quick comparo discovered that I had exactly one 8 flat filter left for the Eldo.  I put it in and secured a new 12 flat wrench from the auto store.  The Stucci wrench went into the cardboard box 'o obsolete tools.
My shiny new '13 Griso and I are headed to the Eastern Shore of Virgina to threaten some flounder with a rod, reel and frying pan sooo...
I got a new 12 flat filter off the shelf and looked at the date:  2008
I tested my new wrench and it was a perfect fit.
I drained the oil and tried to remove the filter, NFW!
I fished the 8 flat wrench out of the aforementioned cardboard box 'o obsolete tools.
Perfect fit and that sucker was on tight.
I checked the date on that UFI filter:  2012!!!  Figures...
I cleaned the bottom of the filter and Sharpied an arrow to mark its position so I can tell at a glance if it is unwinding en route.  I will add the 12 flat wrench to my travel kit as a talisman to ward off leaks.
This is what a Griso looks like:
Offline SED
Re: Oil filter weirdness, Griso edition
« Reply #1 on: June 16, 2016, 12:46:17 AM »
My shiny new '13 Griso and I are headed to the Eastern Shore of Virgina to threaten some flounder with a rod, reel and frying pan sooo....
Great Post   :grin:   (That is a fine looking motorbike.)
I take along spare parts to ward off the demons of badness.
May you catch the big flat one!
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
