Author Topic: low rpm adj  (Read 2775 times)
zari
low rpm adj
« on: June 17, 2016, 04:14:43 AM »
Navada. 750. Model. 94. When is cold  difficult to adj low rpm 1200. Wheh engine get. Warm all OK rpm stable. Why.  ????
 :shocked: :copcar:
Re: low rpm adj
« Reply #1 on: June 17, 2016, 07:14:29 AM »
94? Carb model? Any modifications or changes to stock?
Offline jmac851
Re: low rpm adj
« Reply #2 on: June 17, 2016, 07:30:01 AM »
Idle is supposed to be adjusted when the engine is at it's operating temperature. When they are cold, some of them idle poorly.
1967 V700
1969 Ambassador
1984 Cal 2
1996 Cal 1100
1998 EV 1100
2006 Breva 1100
1994 BMW R1100RS
Re: low rpm adj
« Reply #3 on: June 17, 2016, 07:47:28 AM »
 :1:
Re: low rpm adj
« Reply #4 on: June 17, 2016, 01:46:05 PM »
I think he's saying that the bike won't hold an idle cold -- he has to keep it revved up.  Once warm it behaves.  He's asking why it won't idle cold.  I know nothing about the bike.  I can't help.
Re: low rpm adj
« Reply #5 on: June 17, 2016, 02:18:41 PM »
Yes.  I had the same "problem" with my Sport 1100 and its stock carbs.
Incompetent "dealer" set the idle cold while it was in for a service.  Then it idled at 1800 rpm when warmed.  He couldn't figure out "why".  I asked if he'd warmed it by riding it before setting the idle, and he looked away, looked at the ground, then admitted that he didn't.
So, I ended up setting it myself.  Rode the bike and got it thoroughly warm, then set the idle to 1050 rpm hot.  No, it wouldn't idle without the chokes or throttle for a little while upon startup.  It would cough and die.
Anyway, the OP needs to accept that a carbureted, air-cooled v-twin will not idle well on initial cold startup.  The bike's idle should be set warm.  The small blocks need to idle at 1200-1300 warm.  So, he'd going to have to use the choke and his right hand on the throttle for the first couple minutes after startup.
Offline Mark Harpell
Re: low rpm adj
« Reply #6 on: June 17, 2016, 05:30:17 PM »
After you get the idle set...pick up a Craftsman combo high idle/cruise control at Sears for four or five dollars...works great.....
Mark
