Author Topic: Lemans III to V (1000) Exhaust Swap  (Read 2183 times)
petown
« on: June 17, 2016, 07:12:17 PM »
Just a quick note to confirm that the entire Lemans III exhaust system, including crossover, does fit on a Lemans V.  I came across commentary somewhere that the crossover wouldn't work on the V - that wasn't the case on my bike, anyway.  I swapped out the stock black V system for the chrome III system earlier today.
Offline LeRoy
Re: Lemans III to V (1000) Exhaust Swap
« Reply #1 on: June 17, 2016, 07:16:20 PM »
How does the Le Mans 1000 run with the LM 850 system installed? Were any other modifications done or anticipated? ...carb jetting, timing,...?
LeRoy (Bob Sharp)
Rochester, MI  U.S.A.
'83 1000SP (as of Oct. 15)
petown
« Reply #2 on: June 17, 2016, 07:50:32 PM »
Will have some jets in the mail tomorrow so I'll hopefully know something yet this weekend.
petown
« Reply #3 on: June 24, 2016, 08:46:15 AM »
Sorry for the late reply, Bob.
This is only my second ride on the bike, about 100 miles.  I swapped out slides, needles, mains and pilots per what another poster, who rode at similar altitude (7,000 - 8,500 ft), had suggested some time back.
Overall, the bike runs a lot better - I can't say what the exhaust contribution is, if any.  Dimensionally the mufflers are near identical until the end caps - same exit diameter, though.  Head-pipes carry the same part numbers from 850 to 1000.
I still have some work to do as I am stumbling off idle and have a major flat spot around 4500 rpm.  I can pull through to redline, though.
Offline mtiberio
    • TiberioRacing
« Reply #4 on: June 24, 2016, 09:40:21 AM »
when I read the title, I thought you meant a V1000 I-Convert... The answer is yes...
SportAutomatic.6 by mtiberio, on Flickr
SportAutomatic.4 by mtiberio, on Flickr
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
petown
Re: Lemans III to V (1000) Exhaust Swap and Carb Jetting
« Reply #5 on: October 02, 2016, 08:04:36 PM »
After a lot of experimentation with different slides, needles and jets I finally arrived at a setup that seems to work well with the higher altitude riding I do 90% of the time.  It ended up remarkably close to Ed Milich's recommendations from several years ago.  Again, my bike is stock other than pod filters and the 850 LM exhaust system.
50/3 slides
128 main jets
65 pilot jets
266 AB needle jets
K4 needles set to top groove (leanest)
