Author Topic: 68 Ambassador WILL NOT START. I've tried everything...  (Read 9779 times)
Re: 68 Ambassador WILL NOT START. I've tried everything...
« Reply #30 on: July 06, 2016, 02:03:40 AM »
Blame it on the metric system.
Offline tris
« Reply #31 on: July 06, 2016, 03:35:51 AM »
That's the French for you  :wink:
Now would be a very good time to walk away and come back refreshed and invigorated and nail it in one hit
Good luck
1993 TW125 "POS" - Resting
Offline Mike Tashjian
« Reply #32 on: July 06, 2016, 07:10:18 AM »
Sixties cars with rubber isolated harmonic balancers were notorious for slipping the outside wheel. That left the timing marks pretty worthless. Using just basic tools you can check your timing marks. A drinking straw is about a cheap a tool as you are going to use to find TDC on just about any motor.  That will give you a good start without a Geometry lesson. Sounds like you are just about there. I can almost hear that engine starting.  Mike
Offline redrider90
« Reply #33 on: July 06, 2016, 01:07:38 PM »
If you bent valves you won't have sh*t for compression.
In which case he would not be getting gas vapor blown out the carbs!
Red 90 Mille GT
« Reply #34 on: July 06, 2016, 01:34:09 PM »
I'm following the thread for the conclusion of this mini-drama.   :tongue: :grin:
