Author Topic: Ethanol free gas  (Read 23237 times)
Offline Seamaster
Ethanol free gas
« on: June 27, 2016, 01:43:11 PM »
Ok, this probably is a dead horse, but I researched the Internet, there is still no defiant answer to this. I am living in West Washington State, where are the good places to get ethanol free gas? How reliable is pure-gas.org? I notice the gas station that listed on the pure-gas.org near my house does not have much traffic, i mean there are not many people buy gas over there, their gas may be really old. Is Shell V-Power premium is still ethanol free? Thanks for the help.
« Last Edit: June 27, 2016, 01:45:49 PM by Seamaster »
2016 Moto Guzzi V7II Stone Black
Re: Ethanol free gas
« Reply #1 on: June 27, 2016, 01:50:16 PM »
Isn't Chevron Premium Ethanol free?
Offline redrider90
« Reply #2 on: June 27, 2016, 01:51:48 PM »
I do not want to be snarky. I always wondered what it meant for gas to be "too old". I do not think 6 months or even a year is too old assuming the gas is not picking up condensation. Surly there must be a standard for "too old gas". And for that matter oil. Modern oils are so stabile that they can sit in the garage forever but put it in an engine and then the timer starts. What does Guzziland think? And really Seamaster I am not challenging you, I just thought this would be a good question to ask cause I have always wondered what the answer is.
Red 90 Mille GT
Offline Seamaster
« Reply #3 on: June 27, 2016, 02:00:56 PM »
No offense taken
Offline ITSec
« Reply #4 on: June 27, 2016, 02:01:13 PM »
Old gas can happen from a couple of different causes, so YMMV (literally). Moisture entering the fuel is one thing (not a big issue here in the Mojave, but in Houston or NOLA?  :shocked: ). Volatile elements in the fuel can break down or gas off, reducing its quality - heat accelerates this (definitely an issue here!). Being in an unsealed container (including a vented gas tank) magnifies and speeds up the breakdown and the ability of water to gather in the fuel. Worst case - a half full gas tank (leaving lots of room for air), temperature swings from dew-point lows to warm days (air expansion and contraction 'refreshes' the air in the empty space, bringing in moisture and taking out gassed off volatiles). Since oil is less volatile and more dense, its tendency to do these things is much less (although still present) - but not all oils are 'oils'. For example, brake fluid is tremendously attractive to water vapor and will absorb it from the air faster than you can spell 'hydrophilic'.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline ITSec
« Reply #5 on: June 27, 2016, 02:10:51 PM »
No mainstream company (Shell, Chevron, et al) can be relied on to produce ethanol-free gas unless it is specifically labeled as being ethanol-free. The claim that their premium grades are ethanol-free is a modern myth, since the base stock is the same as their other grades and the additives control the final octane ratings. That being said, some mainstream stations do offer ethanol-free fuel - but it has to have a separate pump and nozzle, and a separate storage tank, making it a costly proposition for that station. Many modern pumps are 'blending' pumps, with two tanks (regular and premium) and the mid-grade(s) being created by drawing a mix from the two tanks together.  Ethanol-free just can't be delivered in that scenario.
Another site to check is http://www.buyrealgas.com/index.html . I would say if a location shows on both sites, and shows signs of traffic, it's likely worth a try.
ITSecurity
Moto
« Reply #6 on: June 27, 2016, 02:42:21 PM »
In Wisconsin, Shell often offers ethanol-free premium gas in bigger cities (or at least in Madison). Kwik Trip offers it more widely. Always labeled, always with a separate nozzle.
« Last Edit: June 27, 2016, 03:30:50 PM by Moto »
Offline Sheepdog
« Reply #7 on: June 27, 2016, 02:57:09 PM »
Ethanol is terrible for aluminum and the 10% stuff actually runs 3-4% leaner than pure gasoline. Out here in Waldheim, we are fortunate to have lots of ethanol-free stations. However, the pure stuff is more expensive and even more so for premium. I use it in my carbureted Triumph and my farm equipment pretty much exclusively. I put it in the Calvin too, but it works okay with the 10% stuff.
Offline Two Checks
« Reply #8 on: June 27, 2016, 03:21:13 PM »
Here in STL metro all gas is EPA mandated E10.
1987 1000 SPII "Il Duce' II"
Offline travelingbyguzzi
  • God hates a coward
« Reply #9 on: June 27, 2016, 04:08:54 PM »
Google ethanol free Washington or click on linky: http://www.buyrealgas.com/Washington.html
73 Eldorado
80 Sp
85 Cal II
97 1100Sport
08 1200 Sport AKA:Sweet Leaf
« Reply #10 on: June 27, 2016, 04:35:31 PM »
So I'm out in the middle of bum-$#@& North Carolina. My low gas light has been on for a LONG time. I finally find a station not horribly far off the Blue Ridge Parkway. I pulled in to the cheap pump. The station owner put down his banjo and run out to tell me his premium gasoline is alcohol free. I told him I like the alcohol. Sure enough, about 1/2 hour later, the rear wheel bearing went out. All because of alcohol in the fuel.
:smiley:
:rolleyes:
Offline old head
« Reply #11 on: June 27, 2016, 05:07:09 PM »
Pure gas is not updated unless someone does in the area, so it may or may not be accurate.  Usually, the station has ethanol free, but only low octane.  Never seen Chevron with ethanol free gas.
Conoco from time to time is the only major brand that I have seen with ethanol free gas.
Old head
06 Breva 1100
Hepco-Becker crash bars
Givi A620 screen
Garmin GPS
Offline Seamaster
« Reply #12 on: June 27, 2016, 05:13:33 PM »
I notice the puregas.com is not up to date, ran to the gas station that is listed, not seems in business. Also I checked the Shell station down the road, there is no where on the pump says ethonal free
Offline Testarossa
    • Skiing History
« Reply #13 on: June 27, 2016, 05:51:06 PM »
For older bikes, a reasonable (though illegal) alternative is aviation gas, the 100LL variety. LL is low lead, so this is verboten in bikes with emissions equipment. Also illegal because you don't pay road taxes on it. Nonetheless very expensive -- around here $4 a gallon. But if the goal is zero ethanol, this is where you're guaranteed to find it.
Offline Idontwantapickle
« Reply #14 on: June 27, 2016, 05:57:37 PM »
Fortunately there is a station about a mile from me with a separate pump for 90 octane with no corn sqeezins. All my non-car stuff loves it. Too much $$$ to run it in a late model car 15000 miles a year! It's about 3.25 now vs. 2.00 for regular at costco today.
So if you want some in Raleigh head to the Marathon on Glenwood at Five Points.
Ask for pump 9  :wink:
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
« Reply #15 on: June 27, 2016, 07:05:21 PM »
I guess I don't understand the need to have alcohol free.
Bike and cars have been running on it fine for a long time.  Only thing I won't put it in is my 2 stroke lawn equipment, only because I leave fuel in the tank almost all year.
Offline Rotten Ralph
« Reply #16 on: June 27, 2016, 07:31:30 PM »
Amen on that. In NJ -no ethanol free pumps so the old bikes get avgas. It's $4 per gallon but well worth it.
I'm waiting for NJ to outlaw farts because they pollute and contribute to global warming.
Never trust a dog to guard your food
03 HD RK / TLE car
65 BMW R69S
60 BSA Gold Star
13 Moto Guzzi V7 Special
Offline Nic in Western NYS
« Reply #17 on: June 27, 2016, 07:33:16 PM »
So I'm out in the middle of bum-$#@& North Carolina...
That's just over the next holler from here.
'04 Ducati ST4sABS
Offline ITSec
« Reply #18 on: June 27, 2016, 07:35:52 PM »
Actually, the science says cow farts are a measurable problem - so if you weigh what a cow does and eat what a cow eats, you are contributing to climate change!  :shocked:
Maybe this is why Chris Christie lost weight?  :evil:
ITSecurity
Offline jackson
« Reply #19 on: June 27, 2016, 07:38:01 PM »
We pay more per gallon for ethanol free gas but we also get 10-12% better gas mileage vs the corn-gas.  Due to the better gas mileage, the total cost for miles driven is almost exactly the same between the two.
We can find ethanol free at four stations that are within five miles of our home so for the last few years, that's all we use.  When we first moved to SC from San Diego, eleven years ago, I bought a new, zero cut lawn mower and several Stihl two stroke power lawn tools. We used E10 (not knowing any better) and within six months, every one of the lawn tools (including the mower) had problems with their carburetors.  That's when we discovered non ethanol and have never had another problem with any of our lawn equipment.
NO longer can ride
« Reply #20 on: June 27, 2016, 07:52:24 PM »
Actually on some days my wife swears that I am the sole cause of climate warming. I plead the fifth!
03 HD RK / TLE car
65 BMW R69S
60 BSA Gold Star
K250
« Reply #21 on: June 27, 2016, 08:08:36 PM »
I use ethanol free in my bikes because it stores better.
FWIW - the fleet expert at a large company I knew made sure all unleaded was used within six months of purchase, and all diesel within one year.     That was 4-5 years ago so maybe things have changed.
Online nc43bsa
« Reply #22 on: June 27, 2016, 08:08:59 PM »
Pure-gas.org is only as accurate as its users make it.  If you spot an error, all you have to do is log on (it's FREE) and post a correction.
I buy gas at several local stations, both E0 and E10, and I try to test it each time.  Every time I've purchased E0, it has tested as zero alcohol.   The E10 lately has been between 5 and 8% alcohol.  I can get 87 and 90 octane E0;  I've been told 91 and higher E0 is no longer produced.
I don't worry so much about E10 in my Buick (aside from the lower fuel mileage) but my mower won't run on E10 longer than 30 minutes, and then it won't restart until I drain the tank and refill.
1990 MilleGT
Offline sign216
« Reply #23 on: June 27, 2016, 09:04:52 PM »
I just found an ethanol free gas station that offers racing gasoline VP 108 at the pump for $10/gallon.  For New England prices that's good, but I think this is leaded, so that's another issue.
I'm talking about Columbus Energies in Swansea, MA;  http://columbusenergies.com/
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Online n3303j
  • Ron Cichowski
« Reply #24 on: June 28, 2016, 12:34:51 AM »
Guess they are near enough to Seekonk Speedway that they have the customers for that product.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline sign216
« Reply #25 on: June 28, 2016, 06:21:42 AM »
Ron,
Makes sense, I forgot about that.  Sadly, I think "VP 108" on the pump  refers to VP fuel C12, which is leaded.  So not good for my Guzzi, unless I want to foul my catalytic converters.
I've got several vintage bikes (and a vintage sidevalve snowblower) that were designed for leaded non-ethanol.  $10/gallon is cheap for race gas, but it's still a little costly for routine operations.
Joe
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline sib
« Reply #26 on: June 28, 2016, 08:54:06 AM »
This thread reads more like a religious revival than a serious fuel discussion.  It is also reminiscent of discussions about food "allergies" and "cleansing" diets.
Ethanol is bad for aluminum??  Show me the facts.
Ethanol-containing fuel doesn't store well?  Since when?  And since when should anyone be storing fuel exposed to the atmosphere, where it can evaporate, anyway?
Labeling of gas pumps?  In my area, the stickers only state that the fuel "may contain up to 10% ethanol".  That means it might contain as little as 0%.  Not very informative.
Better mileage with ethanol-free?  Maybe a bit, but not more miles per dollar.  Anyway, both my car (Prius) and motorcycle (V7II) get better than 45 mpg, so I'm not obsessing about fuel mileage.
Sorry, I'll remain a skeptic, and my cars and bikes will continue to run just fine on fuel that "may contain up to 10% ethanol".  I don't worrying about gumming up the engines on my cars, motorcycles (fuel sits in the tank just fine over winter), or emergency generator (fuel sits in the tank for many months, sometimes years, between uses).  I've got more important things to worry about.
« Last Edit: June 28, 2016, 08:56:42 AM by sib »
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline Testarossa
    • Skiing History
« Reply #27 on: June 28, 2016, 09:02:07 AM »
Many small planes can be recertified to run on hi-octane auto fuel ("mogas"), but not my Piper Comanche. Piper and the FAA were explicit that ethanol would damage the rubber bits in the fuel system, and since the fuel tanks were rubber bladders stuffed into the wings . . .
So I'm not at all surprised to hear that ethanol will cause rubber hoses, o-rings, gaskets and the like to soften or swell.
Offline Two Checks
« Reply #28 on: June 28, 2016, 09:06:34 AM »
Maybe our skeptic should run a vehicle on straight alcohol. Then we'll see if he remains a skeptic.
Offline sib
« Reply #29 on: June 28, 2016, 09:07:09 AM »
Well, all bets are off for antique planes, as for antique cars and bikes, but, this being the 21st century, all recent rubber hoses, o-rings, gaskets and the like are made of modern materials that can withstand ethanol.
« Last Edit: June 28, 2016, 09:18:46 AM by sib »
