Author Topic: What oil filter wrench for a 1200 Sport / Norge?  (Read 18815 times)
Offline willowstreetguzziguy
« on: July 02, 2016, 07:47:04 PM »
Picked up an UFI Guzzi oil filter at the dealer then stopped at an Advanced auto parts store for a filter wrench. With filter in hand, I tried all the ones on display and none fit. So I bought an expanding cam-like wrench for $12. It might work?! It works with a 3/8" wrench and looks like it might loosen the filter but because of the way the cam rotates, it won't tighten the filter. I know some say just hand tighten the filter but I like to snug it up. I can't get my hand up in the recessed area to grab hold of the filter. What do you use?
2008 Guzzi 1200 Sport
Offline ITSec
Re: What oil filter wrench for a 1200 Sport / Norge?
« Reply #1 on: July 02, 2016, 07:58:21 PM »
I use a metal cap-style filter wrench - but then again, I also use Mobil1 M1-102 filters rather than the UFIs...
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
« Reply #2 on: July 02, 2016, 08:02:35 PM »
It depends on what filter you are using. A few years ago, UFI changed from the 8 flat to the 14 flat, IIRC. You may or may not have a NOS old filter. They are out there. I use the Bosch 3330 any more after having too many issues with UFIs. It's an ok filter, available anywhere.
Offline tpeever
« Reply #3 on: July 02, 2016, 08:15:00 PM »
You need to bite the bullet and buy the special wrench if you want to use UFI filters.
2024 Suzuki V-Strom 800
1979 Kawasaki KZ1000 LTD
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1974 Norton Commando
1968 Moto Guzzi V700
1967 Triumph TR6C
1961 Norton Dominator
Offline travelingbyguzzi
  • God hates a coward
« Reply #4 on: July 02, 2016, 08:17:59 PM »
I ended up buying a cheap pair of Chinese channel-locks at Harbor Freight and grinding the OUTSIDE of the jaws down til they fit in the recessed area. They work great and still work as Channel-locks for other uses.
Bill Lovelady      IS
Eskimo  Spy
73 Eldorado
80 Sp
85 Cal II
97 1100Sport
08 1200 Sport AKA:Sweet Leaf
« Reply #5 on: July 02, 2016, 08:43:05 PM »
The filter I just bought is a UFI 8-side filter
« Reply #6 on: July 02, 2016, 08:44:43 PM »
Takes a special wrench, not available in your local auto parts store.
« Reply #7 on: July 02, 2016, 10:56:00 PM »
OK, so the wrench is not available in auto stores (same for the 10-60 Oil), has anyone used an equlivalant Purolator or Fram oil filter?
Offline tpeever
« Reply #8 on: July 02, 2016, 10:58:09 PM »
The recessed nature of the filter mounting is the real problem. Protects the filter nicely but prevents you from using any kind of strap wrench for removal and tightening by hand for installation which are the techniques I use for all other vehicles. I tried everything and then bought the wrench from MG Cycle.
Make sure the rubber sealing gasket comes off with the filter when you change it out. Mine gets stuck periodically.
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1967 Triumph TR6C
Offline tpeever
« Reply #9 on: July 02, 2016, 11:02:05 PM »
I like WIX filters and you should be able to cross reference the UFI or the Bosch on the WIX site. WIX makes filters for Fram but are higher quality. Just make sure specs are the same (bypass pressure etc.)
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1967 Triumph TR6C
Offline mrrick
« Reply #10 on: July 02, 2016, 11:02:22 PM »
Did you try turning that cam-type wrench around?
I use one for both installing and removing.  Just flip it over and it cams in the opposite direction.
Offline craigclu
« Reply #11 on: July 02, 2016, 11:35:25 PM »
I originally got one that didn't exactly work...  It was the proper 76mm, 14 flute but it was plastic and wanted to distort and slip on the filter flutes (actually purchased through a Guzzi source).  I ordered a metal wrench (haven't used it yet) but it seems much more secure.  This is the one I bought and seems a better design for the application:
http://tinyurl.com/gwqaf5b
He who is without oil shall cast out the first rod...”-Detonations 5:72.
« Reply #12 on: July 03, 2016, 12:50:49 AM »
8 flute, 76mm-AF. I can get them at 'Wottalottacrap Auto'. If your local Pep Boys/Auto Zone place doesn't have one they should be able to order one in. They fit filters for a host of vehicles.
Offline drums4money
« Reply #13 on: July 03, 2016, 09:18:29 AM »
+1 on the Bosch 3330.
Commonly available wrench fits perfectly.  Haven't lost a drop after cursing the 1st couple of UFI filters.
Old School Audio:
Offline twodogs
« Reply #14 on: July 03, 2016, 11:13:42 AM »
Hey willow. My wrench is a imperial if-768. 8 sided for the 1200, hope that helps.
1983 Honda CB1100F
2024Triumph 400 Speed x2
Offline ITSec
« Reply #15 on: July 03, 2016, 12:54:43 PM »
Matching filters include:
Purolator PL14476 / PL14477 (PureOne version, preferred over standard Purolator if available)
Mobil1 M1-102 (I use these)
Bosch 3330 (many Guzzi owners like these, often available at WalMart and other mass market sources)
Walmart Supertech ST4967 / 4386 (these test surprisingly well)
Where two filter models are listed, in general the one with the larger gasket ring is preferred (although both fit, the smaller ring may not seal as effectively).
Fram is not recommended by most sources; I cut one apart and decided never to use them again.
See http://www.calsci.com/motorcycleinfo/FilterXRef.html for additional info.
ITSecurity
« Reply #16 on: July 03, 2016, 09:08:47 PM »
Thanks for the info.  I found the Mobil 1 M1-104 oil filter and a corresponding filter wrench at Pep Boys and it went on smooth. It was taking off the old one that was a hassle.
Offline ITSec
« Reply #17 on: July 03, 2016, 09:17:04 PM »
I hope that was a typo - you need the 102, not the 104. The 104 has a stiffer bypass valve rating than the 102, which has the same rating as the stock filter for the CARC bikes.
ITSecurity
« Reply #18 on: July 04, 2016, 12:05:11 AM »
Yes that was a typo. I got the M1-102.
Offline boatdetective
« Reply #19 on: July 04, 2016, 12:31:09 AM »
I have a machined, aluminum filter wrench (sold by Harper's). Trust me on this- just buy the wrench. It is a beautifully made piece of equipment and works perfectly. It;s made my a small machine shop in NH and is worth every penny. It seems hard to justify before you use it...but not at all once you slip it on.
Jonathan K
Marblehead, MA
1981 V50III "Gina"
2007 1200 Sport "Ginger"
Offline OlderSlower
« Reply #20 on: July 04, 2016, 09:43:53 AM »
+1 Boatdetective!
2009 Norge, Staintune, Helibars, lower pegs, Russell seat, Matris fork kit and shock, more to come...
2008 Triumph Bonneville
Offline jreagan
« Reply #21 on: July 07, 2016, 08:41:45 AM »
I have an adjustable one I got at an autoparts store...  Works on all my bikes (including my B1100) to remove the filter...  You can even get one at Harbor Freight with a coupon.
"Loud Valves Save Lives"
2004 Triumph Bonneville T100
2006 Breva 1100 (red)
Nicholasville KY USA
Offline guzziownr
« Reply #22 on: July 07, 2016, 12:16:26 PM »
How many flutes on the Bosch?
Offline Cool Runnings
« Reply #23 on: July 07, 2016, 04:48:05 PM »
How about a screwdriver and hammer?  :popcorn:
Offline ITSec
« Reply #24 on: July 07, 2016, 04:54:56 PM »
Good for removal - problematic for installation of the new one!  :evil:
ITSecurity
« Reply #25 on: July 07, 2016, 05:02:25 PM »
Hand tighten.  :popcorn:
Offline drums4money
« Reply #26 on: July 07, 2016, 05:20:36 PM »
14 flutes
I got the wrench and the 1st filters at AutoZone to make sure they were simpatico.  Now I just order a filter occasionally from Amazon when I know I've got an oil change on the horizon.  I've never had to crank on it to get a good seal.  Hasn't lost a drop with the Bosch. Although the wrench adapter is stamped steel, I've not had any issues with the filter binding or not wanting to release.  Works like a cheap little champ!
« Last Edit: July 07, 2016, 05:28:16 PM by drums4money »
Old School Audio:
Offline nwguy
    • Jim Gallant's home page
« Reply #27 on: June 10, 2021, 10:40:19 AM »
Will these filters fit a 2008 Norge with the 2 valve engine vs. 4 valve?
« Reply #28 on: June 10, 2021, 10:51:11 AM »
I use the Bosch 3330 and this wrench "Amico+74mm+Inside+Dia+13mm+Square+Drive+14+Flute+Oil+Filter+Cap+Wrench"
I got the wrench on Amazon back in 2014. That particular link is dead now but you can search, they are still on the site
I have mostly stuck with the bosch because my Subaru uses a 3333 and the Breva 3330 so it's easy to remember- plus it's the same wrench for both
« Last Edit: June 10, 2021, 11:00:00 AM by Mayor_of_BBQ »
« Reply #29 on: June 10, 2021, 10:53:19 AM »
yessir
