Author Topic: Breva 750 Fuel Vapor Recovery System Replace or Ditch?  (Read 2163 times)
Offline EyedocKav
« on: July 09, 2016, 04:00:13 PM »
Hey Guys,
My Breva 750 fuel tank was damaged in a fall and needs to be replaced.  In addition to the tank, the fuel vapor unit was damaged (nipples broken).  Since the fuel vapor unit was only on US bikes, does anyone know if I can just remove it instead of replacing it?  If removal is possible do I just cap the two nipples under the gas tank?  Appreciate the help!
Offline timonbik
Re: Breva 750 Fuel Vapor Recovery System Replace or Ditch?
« Reply #1 on: July 10, 2016, 09:44:33 PM »
I haven't ditched mine yet but it is in the cards.  You need to cap the line/ lines that feed into the throttle bodies.  The line from the tank should remain open for venting.
2008 BREVA 750
2020 V85TT ADV rosso
2016 APRILIA SHIVER 750
2013 VICTORY JUDGE CUSTOM
2013 VICTORY XR CLASSIC
2006 VICTORY V92TC
Offline sign216
« Reply #2 on: July 11, 2016, 07:40:44 AM »
I ditched mine.  No difference either way.  I second Timonbik re capping the lines and leaving the vent line open.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
