Author Topic: best gas siphon ?  (Read 3453 times)
Offline redrider90
best gas siphon ?
« on: July 10, 2016, 11:12:43 AM »
I've been looking for a decent gas siphon to keep around esp. for use with the small generator. I see on ebay that Flo N Go seems to be the most popular brand. I want one I can transfer from cars to containers as well as moving from 5 gallon to easier to handle 2 gallon containers.
What you say out there?
Red 90 Mille GT
Offline not-fishing
Re: best gas siphon ?
« Reply #1 on: July 10, 2016, 11:18:43 AM »
What and not get a mouthful of gas?
Where's the sport in that?
Mark
« Last Edit: July 10, 2016, 05:21:56 PM by not-fishing »
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
« Reply #2 on: July 10, 2016, 11:28:26 AM »
We got one at the shop, it uses a pcv valve type ball in the hose .
When you shake it back & forth it starts the flow going, pretty slick!! I have no idea who makes it. you connect a hose to each side of it.
Offline Adk.IBO
« Reply #3 on: July 10, 2016, 11:43:32 AM »
I love my cranky pump from Aerostitch. Use it for my small engines and carry it on the bike.
PS: just looked through the catalog quick and did not spot it, it may not be available anymore..? There is an e-siphon(?).
PPS: googled Cranky Pumps and it took me to it on the Aerostitch site- $42 pricey but worth it to me..."best" being the key word.
« Last Edit: July 10, 2016, 03:05:49 PM by Adk.IBO »
Luke 23:34
« Reply #4 on: July 10, 2016, 02:25:00 PM »
I use a big washer made from a scrap of inner tube.  It fits tightly on my siphon hose, and is big enough to cover the car's gas tank filler tube.  With the siphon tube inserted through the washer into the gasoline in the car's tank, I hold the washer against the filler opening and blow a big breath into the tank, then while still holding the washer in place, put the outer end of the tube in the can to be filled.  Pressure in the car's tank then starts the siphon if I don't delay too long.
A piece of closed cell foam around 1/2" thick is an improved version of the washer.  Its stiffness makes it easier to seal to the car's filler tube.
« Last Edit: July 10, 2016, 02:25:26 PM by Triple Jim »
LaMojo
« Reply #5 on: July 10, 2016, 02:50:45 PM »
I use a outboard motor squeeze primer bulb and a length of hose on each end.
Offline sib
« Reply #6 on: July 10, 2016, 03:26:59 PM »
Where's the sport in tthat?
Mark
I used to do that often in the days of leaded gas, and never thought much about it.  No wonder I can't solve the Schroedinger equation.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline sib
« Reply #7 on: July 10, 2016, 03:30:12 PM »
Cranky Pump looks nice, but is spec'ed to pump only 1 gal/2.5 minutes, too slow for transferring fuel to/from a generator.
Offline ITSec
« Reply #8 on: July 10, 2016, 04:06:06 PM »
Just calculating that out, that means the generator would be consuming 24 gallons per hour to outrun the pump!  :grin:
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline yogidozer
« Reply #9 on: July 10, 2016, 04:16:19 PM »
Mark
Why not ask a friend? What are friends for? http://wildguzzi.com/forum/Smileys/default/laugh.gif
Offline Hit Man
« Reply #10 on: July 14, 2016, 01:38:25 PM »
Best siphon ever:
has a glass marble in the copper end - you can hear it working even if the fluid is clear.  Big flow;  just shake it and it works.
https://www.amazon.com/Hopkins-10801-FloTool-Shaker-Anti-Static/dp/B000EH0ORI/ref=sr_1_1?ie=UTF8&qid=1468521015&sr=8-1&keywords=flotool+shaker+siphon
Griso: -noun  Slang.  ‘hit man’    e.g., to 'grease' someone   Origin: Italiano 2007 (plus Todd Haven-rip)
MGNOC
AMCA
VJMC
2007 Griso  - with the long pushrods
1971 Ambo - long in the tooth
1973 Honda CL350 K5  - long chain
1989 Suzuki Katana 750 (long gone)
1989 Suzuki GS500E (long gone
Offline cookiemech
« Reply #11 on: July 14, 2016, 04:20:27 PM »
I'm going to use that excuse from now on . . .  :grin:
