Author Topic: Griso dry clutch rattle vs Breva dry clutch rattle  (Read 3463 times)
Doppelgaenger
« on: July 10, 2016, 02:45:56 PM »
Can somebody tell me why the Griso's clutch rattles with the clutch lever out vs why the Breva's clutch rattles with the clutch lever in?
Re: Griso dry clutch rattle vs Breva dry clutch rattle
« Reply #1 on: July 10, 2016, 04:23:29 PM »
Which Griso? The 1100 uses the same clutch as the Breva and it will rattle when the lever is pulled in. The 1200 uses a different clutch which, if the bike is tuned correctly, is virtually silent. If the throttle bodies are out of whack though the gearbox will 'Knock' when the lever is released.
« Reply #2 on: July 10, 2016, 10:05:09 PM »
Over time the catylitic mufflers  will rattle some times when the bike is running too.
« Reply #3 on: July 10, 2016, 11:19:24 PM »
Funny, my B750 goes quiet when I pull the lever in. :huh:
Offline Jdcooper
« Reply #4 on: July 11, 2016, 07:12:58 AM »
I've wondered the same thing. My B11 rattles like a bucket of bolts w the clutch in. Stelvio...not at all.
Doppelgaenger
« Reply #5 on: July 11, 2016, 11:17:16 AM »
It was the 1200, and it was definitely the clutch making the noise because it'd stop making it with the lever in. Reminded me of a ducati in the way that it rattled just sitting there. It's not noticeable like the breva which sounds like a bunch of clutch disks being put thru the washing machine... The bike did have about 7000 miles on it though.
« Reply #6 on: July 11, 2016, 02:45:29 PM »
Yes, it stops making the noise when you pull the lever in because the input shaft to the gearbox stops rotating. The 270/450 firing intervals mean that input shaft speed will be uneven, if the TB's are out of whack the problem is exacerbated. It's not the clutch.
Online PJPR01
  • Norge, Scura, Griso
« Reply #7 on: July 11, 2016, 10:51:48 PM »
Perhaps single clutch vs. double clutch plate?
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
