Pulling the main fuse to re-trim the ECU (after installing the Agostini). 1. Where is the main fuse?2. Will I need to reprogram the display (change KM to Miles, etc)?Sounds like I need to make a choice, either leave the DB killer in or remove it, don't keep changing it in and out? Also I'm, thinking of cutting the DB killer half way to quite it down a bit but still give it some authoritative sound?
