Author Topic: Breva 1100 valve adjustment - sanity check!  (Read 6082 times)
Offline tris
« on: July 18, 2016, 06:55:25 AM »
Just to make sure I've got my had around this properly!!!
On my B11 I set the engine to TDC on the compression stroke (inlet having closed on the up stroke) and I adjust the valves on the same side?
Its my age - I'm having a bit of brain fade  :embarrassed:
1993 TW125 "POS" - Resting
Re: Breva 1100 valve adjustment - sanity check!
« Reply #1 on: July 18, 2016, 07:13:33 AM »
Treat it like two separate single cylinder engines. Each side has to be set up as you describe. Crank rotates clockwise when viewed from the front.
Offline tris
« Reply #2 on: July 18, 2016, 08:05:18 AM »
Thanks Pete!
Thinking of it as 2 singles is a great help!
Offline acogoff
« Reply #3 on: July 18, 2016, 08:22:07 AM »
     Finger in sparkplug hole, feel for compression gets you on the correct one - easy enough.
Marshall County Minnesota USA
« Reply #4 on: July 18, 2016, 10:03:36 AM »
I never liked the feel for it method because I liked to turn the motor extra slowly (usually with a socket on the crankshaft) and observe the valve motion to be certain I didn't miss it.
So like Pete says, I'll observe and treat each side as its own entity.
I'll add that on my Guzzis I'll make my own timing marks with a Sharpie:
1. One mark on the crankshaft nut.
2. Two marks on the front face of the crankcase assembly - L for the left cylinder and R for the right cylinder.
Now one has to remember that when those marks align, just like any marks on the flywheel, all you know is that the PISTON is a TOP DEAD CENTER of travel, but you don't know if that is TDC of Compression or Exhaust stroke unless you ALSO watch the valves. Which is simple to do since you've got the valve cover off so you can check and adjust them.
Then all you need to remember is the whole POINT of the Compression stroke is to compress the air/fuel mixture introduced into the chamber by the open INTAKE valve, so the Compression stroke starts as the intake valve closes.
Easy-Peasy
Offline tris
« Reply #5 on: July 18, 2016, 02:03:35 PM »
I like to straw/chopstick/screwdriver down the plug hole even less. That feels like an accident waiting to happen.
I'll get it sorted  :thumb:
Doppelgaenger
« Reply #6 on: July 18, 2016, 02:41:44 PM »
I was able to do it visually. It's very hard to get the angle right so that light will reflect off the top of the piston, but when you get it just right it's easy to see when the piston hits TDC.
« Reply #7 on: July 18, 2016, 02:55:48 PM »
Just watch the valves, at TDC on the exhaust stroke the exhaust valve is closing while the inlet is opening
Turn it one full rotation from there with something soft down the plug hole.
I put the bike in top gear and sort of knock it back and forth using the back wheel.
« Last Edit: July 18, 2016, 02:58:03 PM by Kiwi_Roy »
Offline tpeever
« Reply #8 on: July 18, 2016, 03:06:46 PM »
Turn it one full rotation, I put the bike in top gear and sort of knock it back and forth using the back wheel.
I like the "watch the valves method" as well with both spark plugs removed and turning the engine via socket on crankshaft rather than the rear wheel. I can see what is going on better turning the engine over from the front and it seems more precise. Whatever side I am working on, I just look for the intake opening and then closing on that side, then confirm TDC for that cylinder with TDC tool, straw, peering into cylinder with flashlight, whatever. Confirm that both rockers on that side are loose and adjust away. Repeat operation for other side. I also like Pete's suggestion of thinking about each cylinder independently.
2024 Suzuki V-Strom 800
1979 Kawasaki KZ1000 LTD
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1974 Norton Commando
1968 Moto Guzzi V700
1967 Triumph TR6C
1961 Norton Dominator
Offline jreagan
« Reply #9 on: July 18, 2016, 03:46:08 PM »
Me too.
I just replaced my B1100's left cover gasket yesterday since it was leaking (I bought the MGcycle metal core replacements).  I figured I'd check my clearances while I was there (intake was just over 4, exhaust was just under 6 - I left them alone).  I found that even in high gear and on the center stand, I had a bitch of a time moving the rear wheel.  The socket on the crankshaft was the only way I could get it right.  I watched the valves and used a straw.
And yes, I removed the grill so I could lean the tank forward enough for bolt access.  That upper corner still a PITA and I could only get at it with a hex key.
Torqued back to 10Nm
"Loud Valves Save Lives"
2004 Triumph Bonneville T100
2006 Breva 1100 (red)
Nicholasville KY USA
Online bad Chad
« Reply #10 on: July 18, 2016, 03:55:14 PM »
I'v put various parts of my body in the spark plug whole; just experimenting as to what works best.  I'm still not sure I have in nailed yet, but I'll get there.
« Reply #11 on: July 18, 2016, 04:08:09 PM »
 :1: for the straw. If both the valves are up it is on the compression stroke.
I have used a screwdriver but don't like to. Sometimes the pressure from the springs will suddenly pop the piston up and trap the screwdriver. No problem with a straw.
Offline normzone
« Reply #12 on: July 18, 2016, 05:00:00 PM »
I am unable to get any of my parts in there, due to diameter issues - that's probably a good thing.   :laugh:
Offline tpeever
« Reply #13 on: July 19, 2016, 06:40:24 PM »
A TDC tool and a timing disc are useful tools to have if you work on a lot of different bikes and like to time them from first principles or just to check on pre-existing timing marks etc. Timing marks on the cam gears on my Triumph TR6C were incorrect so only way to get it running was to set valve opening timings from scratch. The other nice thing about a TDC tool is that there is no danger of it falling into the cylinder compared to a straw or wheel spoke and they are inexpensive. You can always make your own timing disc by printing one out and gluing to cardboard but I recently bought a nice aluminum one form Motion Pro. Very nice.
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1967 Triumph TR6C
Offline Idontwantapickle
« Reply #14 on: July 19, 2016, 09:36:54 PM »
Just turn on the ignition, stick your finger in the appropriate plug cap and turn the engine. When it shocks the s#&@ out of you it's on the money!  :evil:
Seriously, it just takes practice.
https://www.youtube.com/watch?v=hSO0dphXx-w
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline willowstreetguzziguy
« Reply #15 on: July 20, 2016, 12:48:30 AM »
Nice video, thanks!
2008 Guzzi 1200 Sport
Offline ken farr
« Reply #16 on: July 20, 2016, 09:32:41 AM »
Genius !!!
So obvious, I am going to usurp your idea and use it as my own.
 :bow:
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
