Author Topic: Breva handlebars  (Read 2082 times)
Offline Noguzznoglory
Breva handlebars
« on: July 24, 2016, 12:14:26 PM »
Considering putting wider handlebars on the Breva 750. Anyone done so or have a reccomendation for a set that works well.
93 750 Nighthawk
73 Honda CB350
73 Honda CL450
04 Breva 750
15 Norge
16 VERSYS 650
Offline BMCMOTO
Re: Breva handlebars
« Reply #1 on: July 24, 2016, 12:21:10 PM »
I installed a set of risers for someone.  The cables have very little excess,  3/4"  rise was nearly impossible with existing cables.  Some of the later smallblocks may have longer cables.   Good luck, and please report back with information on you quest.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
« Reply #2 on: July 25, 2016, 01:17:07 AM »
I found the Breva handlebars perfect for me.  :thumb:
« Reply #3 on: July 25, 2016, 02:47:36 AM »
 :1: My first thought to the question was, why?
Offline BMCMOTO
« Reply #4 on: July 25, 2016, 06:01:48 AM »
I wondered why at first as well.  I had information about the cable problem that I thought pertinent for the project, so related that.  Sometimes why is not really important, many people do things to motorcycles I would never do.  I have seen many things but probably the oddest was a customer who positioned his clutch lever so that it depressed the flash to pass button, his complaint was the high beam wouldn't function, the fuse was blown, replaced the fuse, repositioned the lever to just miss the button.  Two weeks later he returned with same problem, same cause, explained it to him again, "If you hold this button in for extended periods of time, traffic lights etc, it will blow the fuse."   Go out and reposition your lever so that it will hit the flash to pass button and see if you can ride your bike with the lever in that position.  The bike was a 90s California model but I really don't think it matters.  It takes all kinds to make a world.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline sign216
« Reply #5 on: July 25, 2016, 05:41:50 PM »
Brian
I put 3/4 or 1" risers on my V7.  There was enough cable slack to do it, but I had to disconnect and re-route the clutch cable.  All good after that.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #6 on: July 26, 2016, 05:08:50 AM »
As to the why.....
I was just looking to widen the hand position. The stock bars make the bike feel "small" to me.
93 750 Nighthawk
73 Honda CB350
73 Honda CL450
04 Breva 750
15 Norge
16 VERSYS 650
