Author Topic: HD Air shocks and brake adjustment  (Read 1556 times)
Offline vf84pc
« on: July 25, 2016, 10:26:32 AM »
I was thinking about putting the HD Showa air shocks on my 04 EVT. Any advise or recomendations? Is there a procedure for adjusting the proportioning brake valve?
Re: HD Air shocks and brake adjustment
« Reply #1 on: July 25, 2016, 01:35:10 PM »
I'd think the brake valve wouldn't need any adjustment so long as the length of the shocks didn't adversely affect the ride height.
Offline bigbikerrick
« Reply #2 on: July 25, 2016, 01:40:03 PM »
I have a set on my 03 aluminum, I never messed with the adjustment on the proportioning valve myself, but I believe the HD shocks are a bit shorter, so the proportioning valve would sense that swingarm angle as meaning the bike has a heavy load on it. I believe that diverts more braking pressure to the rear to  balance out the braking.
Rick.
« Last Edit: July 25, 2016, 01:41:09 PM by bigbikerrick »
Offline vf84pc
« Reply #3 on: July 25, 2016, 07:43:10 PM »
Yes so how do I adjust that Valve to compensate for the 13" HD shocks vs the 14" stock units.
« Reply #4 on: July 25, 2016, 07:51:34 PM »
From the service info, it should be 67mm per the drawing, when on the center stand.
I think it you adjust it for this, you will be close.
BTW, I have played a bit with the setting on my 2004, and never did notice a real change.
