T3 wire wheels on 850 Lemans
Topic: T3 wire wheels on 850 Lemans (Read 3289 times)
steven c
July 26, 2016, 08:07:50 PM »
So what is involved in putting a set on T3 wheels on my 77 lemans? I know the spacing is different on the front. Can I just put them on or is there more to it?
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
guzzista
Re: T3 wire wheels on 850 Lemans
Reply #1 on:
July 26, 2016, 10:39:24 PM »
Rear= You will need the left side spacer/ disc carrier, the wheel bearing spacer. On the drive side you can swap the spline plate, fiber disc , check image
http://www.stein-dinse.biz/eliste/index.php
. For the front you will need:
http://hmb-guzzi.de/Front-wheel-flange-set-narrow-version-LM-1-LM-3-750-S3-etc
. Also this might help for the rear:http://hmb-guzzi.de/Rear-wheel-flange-set-T3-750-S3-etc
Reply #2 on:
July 26, 2016, 10:40:33 PM »
HMB sells a complete flange and axle set for the LM1 / S3 etc. I used these on my 750 S3 rebuild (my axle was all rusted and this kit is cheap), standard 859 T3 wire wheels will fit these flanges and the forks.
guzzista
Reply #3 on:
July 26, 2016, 10:50:14 PM »
Oh, and , as per the brake discs/ rotors, you will have to go to the shallower T/T3 front rotors, or you can use these:http://hmb-guzzi.de/Front-Brake-Disc-Kit-300-mm-floating-T3-SP-Cali-2etc or these
http://www.mgcycle.com/index.php?main_page=product_info&cPath=110_134&products_id=2652&zenid=0b80317671892a251e352209e99d67b9
. For the rear , you can re-use the LM rear disc. Cheers
Arizona Wayne
Reply #4 on:
July 26, 2016, 10:54:57 PM »
I took a rear spoked rim from a `77 Convert. and put it on my `81 CX100(LM II). It had a spacer with it on the left brake side compared to the mag rim I took off. I installed the CX mag rim on the same Convert. Haven't switched front rims yet but might. Already know the ID between the brake rotors are the same but the forks on a CX/LM II are wider than on a LM I.
Last Edit: July 26, 2016, 10:56:26 PM by Arizona Wayne
steven c
Reply #5 on:
July 27, 2016, 06:16:11 AM »
Great info thanks. A little more involved then I thought.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
mtiberio
Reply #6 on:
July 27, 2016, 06:47:13 AM »
really not that bad, the rear goes right on, the front needs some narrowing of the bearing carriers.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
peake271
New Egg
Reply #7 on:
October 06, 2016, 02:09:23 AM »
If you don't end up putting the spoke wheels on I might be keen on buying them off you
