Author Topic: help on Continental F163 tractor engine  (Read 4772 times)
« on: July 30, 2016, 12:50:25 PM »
I have a F163 flathead in a wood chipper. The engine has 12 hours on it since total rebuild. It has a slight miss I'm trying to fix. I'm setting the valves and Continental wants them set at operating temp. So I'm doing it cold. Hot is sposed to be IN .012, EX .020.   A search of the internet has the setting cold all over the map, my notes say .018 both cold. What say you?
Offline Two Checks
Re: help on Continental F163 tractor engine
« Reply #1 on: July 30, 2016, 01:43:12 PM »
My search found .010 In .020 Ex HOT.
They sure want to make sure those valves are well seated.
1987 1000 SPII "Il Duce' II"
« Reply #2 on: July 30, 2016, 01:53:20 PM »
its a flathead. It will not be set hot. To access the tappets the carb is removed. A parts guy who claimed he was experienced some years ago said they always set them cold and it was at .018 both. Do I believe him? Im leaning that way, just thought Id ask here, seems like a good idea
Rough Edge racing
« Reply #3 on: July 30, 2016, 02:36:02 PM »
  Flathead valve train is short and unlike an OHV, expansion of the block and push-rods with temperature , the flattie valve clearance can be be off a bit and not be an issue. Typical side valve clearances for smaller Continental  engine is .014 on both ,cold....
« Reply #4 on: July 30, 2016, 08:47:51 PM »
« Last Edit: July 31, 2016, 07:46:22 AM by John A »
« Reply #5 on: July 31, 2016, 07:42:08 AM »
Before
« Last Edit: July 31, 2016, 08:07:07 AM by John A »
« Reply #6 on: July 31, 2016, 02:36:42 PM »
needs bondo.
« Reply #7 on: July 31, 2016, 03:38:47 PM »
yes it does. are you volunteering ? :azn:
« Reply #8 on: July 31, 2016, 03:45:07 PM »
I'll volunteer, but you won't like it.  I rivet my bondo on.  You know I do.   :evil:
