Author Topic: OT: Self Propelled Mower pulls left...  (Read 12135 times)
Offline GearheadGrrrl
« on: August 04, 2016, 03:54:33 PM »
The patient is a 5 year old Honda walk behind with enough hours on it that I should start looking for a replacement... Actually worn the Honda OHC engine to the point it needed a valve adjustment. Broke the drive belt to the rear drive gearbox, replaced with a new belt and it pulls to the left. Had to clean out all the vegetation on the right side to get the belt in, was wondering if that threw it "off balance"? Cleaned out all the vegetation on the left side to equalize the drag, but it still pulls left. Any ideas?
Guzzi: Quota with Motorvation 'hack
BMWs: F800S, R100GS, R80ST with Motorvation Spyder 'hack, R65LS
Hacks: Motovation Spyder and Formula II
Buell: M2L, RIP Buell Motors Corporation
Yamaha: MX250 $25 auction find, "static display" for now, XS650 "on loan" from my brother, 'nother "static displa
Offline Perazzimx14
Re: OT: Self Propelled Mower pulls left...
« Reply #1 on: August 04, 2016, 04:41:24 PM »
is it set up to run dirt track?
Offline yogidozer
« Reply #2 on: August 04, 2016, 05:01:29 PM »
check tire pressure, maybe a dragging brake?
Offline normzone
« Reply #3 on: August 04, 2016, 05:10:37 PM »
Did you have to loosen the gear box mounting to get the belt on? Perhaps there's a little wiggle room in the mounting, and it's oriented off a little?
I'm just spitballing here...
 :popcorn:
Offline CalVin2007
  • fickle old fool
« Reply #4 on: August 04, 2016, 05:21:10 PM »
 Are both wheels pulling? If the left isn't, the RH wheel will turn the machine left....
'07 CalVin
 '79 TT500
 '78 SR500
 '80 SR500
« Reply #5 on: August 04, 2016, 05:35:46 PM »
 Isn't that backwards ???
Offline CalVin2007
  • fickle old fool
« Reply #6 on: August 04, 2016, 05:41:32 PM »
   Don't think so....I believe the Honda is rear wheel drive.
'07 CalVin
 '79 TT500
 '78 SR500
 '80 SR500
« Reply #7 on: August 04, 2016, 05:51:20 PM »
The mower is rear drive, and when I have the drive wheels off the ground both turn, so some power is going to the left wheel.
« Reply #8 on: August 04, 2016, 05:57:34 PM »
 Is it a simple solid axle design ?
Offline slopokes
« Reply #9 on: August 04, 2016, 06:14:25 PM »
right front signal is bad-- change it :boozing: :boozing: :boozing:
Offline rtbickel
« Reply #10 on: August 04, 2016, 06:16:52 PM »
Sounds like it could use a shim or two.
2020 V85TT
LaMojo
« Reply #11 on: August 04, 2016, 06:21:25 PM »
Check key on driveshaft for gear behind left wheel.
Online fotoguzzi
« Reply #12 on: August 04, 2016, 06:48:27 PM »
is that counter steering 101?
Online RinkRat II
  • Lake Powell AZ
« Reply #13 on: August 04, 2016, 08:18:16 PM »
  Torque steer, Hondas are notorious  for that. Needs more stagger..... What kind of oil ya runnin'? :evil:
    Paul :boozing:
Offline Scott DeRoss
« Reply #14 on: August 04, 2016, 08:24:16 PM »
Check your tire pressures! next on the list would be brake adjustments, I know my exmark has wing nuts in several areas in the linkage to lengthen or shorten rods. Then I would go to the tensioner springs, maybe pulleys, finally belts. Process of elimination, something is wrong with a system, break it down into parts and segments systematically. Scott
2007 Vintage (Vinnie)
2017 V9 Roamer (Sunny)
1-76 & 3-78 Robins
1975 Honda CT90
1979 Beneli G2 moped
75 850t wifes (Plum Crazy)
79 Honda Ct70 (restored)
MGNOC L-661
Never take life so serious you won't get out of it alive
« Reply #15 on: August 04, 2016, 08:31:42 PM »
 Uh fellas , this is a WALK BEHIND mower , not a rider .
« Reply #16 on: August 04, 2016, 09:19:50 PM »
thanks Mr Ackerman.
« Reply #17 on: August 04, 2016, 10:31:42 PM »
 So mow counter clockwise.
Offline tris
« Reply #18 on: August 05, 2016, 12:14:00 AM »
My mower has a weird one way dog clutch in each wheel made from monkey metal. One of mine is knackered so only drives one wheel instead of two
Might be worth a look
1993 TW125 "POS" - Resting
Offline wrbix
« Reply #19 on: August 05, 2016, 01:24:41 AM »
Should've replaced BOTH drive belts, getting  just enough slip on L to cause difference in drive with load.
Bill in VA, sometimes FL
"Eschew aphorism"
LeMans IV - "Giulia"
Lario - "Giulietta"
V50III cafe'd - "Leggera"
‘77 Convert - “Sofia”
Classic Mini
‘60 Austin Healey Sprite
Caterham Super Seven Sprint
‘13 Audi TTRS
Grumman AA5B (sold)
« Reply #20 on: August 05, 2016, 03:15:29 AM »
G.G. said in post that she replaced the belt drive to the rear drive gearbox, so I presume there is only one belt. Never seen that model but if it has a diff in there it may be driving one wheel more than the other, although if both wheels turn when the machine is lifted up them usually that side of things would be ok. If it is a live drive I would have no idea why it would go round in circles other than a flat tire.
Offline wrbix
« Reply #21 on: August 05, 2016, 05:59:06 AM »
Ah, right you are - misread "rear" for "right".
Reading comprehension is the third thing to go with advancing age.
"Eschew aphorism"
Lario - "Giulietta"
Classic Mini
‘13 Audi TTRS
Grumman AA5B (sold)
« Reply #22 on: August 05, 2016, 06:31:50 AM »
 How could a walk behind have a flat tire ????  :laugh:
« Reply #23 on: August 05, 2016, 08:04:52 AM »
There's only one belt, it runs from a pulley on the crankshaft just above the blades to the rear drive gearbox. There's some gears in there to make the power take the ninety degree turn and some reduction gears, no differential though. Tires are solid rubber, so they're already flat.
Offline sib
« Reply #24 on: August 05, 2016, 10:29:19 AM »
Paint it red, it might then pull to the right  :laugh:
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
« Reply #25 on: August 05, 2016, 03:50:49 PM »
You could ask this Honda Customer Service Representative .......
.  :huh:
Offline normzone
« Reply #26 on: August 05, 2016, 04:00:13 PM »
Perhaps the breaking of the drive belt event had further ramifications than just the belt, and something in the black box that turns motion around the corner took a hit at the same time?
« Reply #27 on: August 05, 2016, 04:08:30 PM »
Penderic, I was just telling my son about a place out west called "The Cosmos" that I visited about 45 or 50 years ago.  That photo is either the same place, or one very similar.  It was a shack on a hill, with lots of illusions resulting.
« Reply #28 on: August 05, 2016, 04:10:29 PM »
Easy. Big walk behinds have pneumatics. <shrug>
« Reply #29 on: August 05, 2016, 04:12:00 PM »
Seized L.H. front wheel?
