Author Topic: V7 II slow to start after gas stop  (Read 1371 times)
Offline Jim C
« on: August 06, 2016, 05:25:42 PM »
Hey, guys,
I hopped on the bike to go get gas this afternoon, and stopped
at a Philips 66 gas station. I filled up with non-ethanol gas (first
time doing that). Anyway, 92° F, but I had to get out of the
house (hope I never have to move again).
Got back on the bike, turned the key, and got rrr-rrr-rrr, rrr-rrr-rrr,
slowly. I turned key off then back on, then got rrr-rrr-RR, rrr-rrr-RRRVrooom
slowly again, and then it started and idled fine.
It sounded like the bike wasn't going to start. YIKES!! I thought I was going to
be stuck at the gas station.
Other than that, the bike ran great, and no other hiccups.
Any ideas what would cause that?
As always, I appreciate your wisdom.
Jim
« Last Edit: August 06, 2016, 06:42:21 PM by Jim C »
2016 Red V7 II Stone
Re: V7 II slow to start after gas stop
« Reply #1 on: August 06, 2016, 05:35:34 PM »
A common fault with bikes with the charcoal canister seems to be the tank pressurising, especially in hot weather. If it happens again, try venting the tank.
Online Cam3512
« Reply #2 on: August 06, 2016, 08:53:12 PM »
Happens to mine on occassion, even AFTER the canisterectomy.  Right after filling up.  No clue.
« Reply #3 on: August 06, 2016, 09:18:17 PM »
Overfilling WITH a carbon can can burp a little gas into the can, and you need to run a little to get the fumes out.  Overfilling WITHOUT a carbon can can burp a little gas into the throttle bodies.  Then you deal with a shot of raw gas in the intake to overcome before the engine will start v dealing with fumes and a little rough running after you start.  But remember -- the canister is evil.  It must be eradicated!   :rolleyes:
Or you could not overfill the tank or spill gas into the vent tube.  That works, too.
