Author Topic: 850T Sidestand: Good or bad?  (Read 4599 times)
Offline swooshdave
« on: August 11, 2016, 08:42:58 PM »
https://youtu.be/4gMUAVIQEVY
I don't know if this thing should do this. I also can't figure out what the roller at the top of the mount is suppose to do.
It seems sturdy and at 800lbs for the stand alone it should be.  :undecided:
Side question: Does this side stand limit the choices for headers?
2001 V11 Sport
Re: 850T Sidestand: Good or bad?
« Reply #1 on: August 11, 2016, 09:04:39 PM »
Worlds best ss.. That cam locks it in place when weight of bike is on it. Should not interfere with any headers.
Offline swooshdave
« Reply #2 on: August 11, 2016, 09:08:52 PM »
So aside from scruffy looking it appears normal?
What does the stand pivot on? Are there wear parts? Just throw a handful of grease in there every once in awhile?
2001 V11 Sport
« Reply #3 on: August 11, 2016, 09:20:06 PM »
I sure like the brown side stand on my LMIII. Make that look like a POS <sorry>  :laugh:
Offline swooshdave
« Reply #4 on: August 11, 2016, 09:38:28 PM »
It's quite the contraption.
2001 V11 Sport
Offline n3303j
  • Ron Cichowski
« Reply #5 on: August 11, 2016, 10:08:25 PM »
Love that setup on the T3. I can park nose down on any downgrade and not worry about the stand folding even if the bike wants to roll forward.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #6 on: August 11, 2016, 10:11:32 PM »
I have a Brown side stand on my V7 Sport and will be installing on eon my 750S as well. The mounting is hidden and the quality is super. Very stable stand.
Boxerworks sells them to fit the Tonti frame
http://www.boxerworks.org/new-parts/misc-accessories/brown-sidestand/
Offline n3303j
  • Ron Cichowski
« Reply #7 on: August 11, 2016, 10:36:50 PM »
Browns look nice and are well made. Had one on my BMW R100RT. But they will sink into soft stuff more easily than the Moto Guzzi  Police stand. They will also fold if parked nose down on a sufficient incline. The Guzzi Police Stand made the bike a stable tripod on anything but quicksand.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline swooshdave
« Reply #8 on: August 11, 2016, 11:22:10 PM »
I wouldn't put it past surviving quicksand!
2001 V11 Sport
« Reply #9 on: August 11, 2016, 11:43:22 PM »
  I never use them.
Offline swooshdave
« Reply #10 on: August 12, 2016, 12:29:35 AM »
  I never use them.
Lean them against trees?
2001 V11 Sport
Offline Groover
    • Scooteropolis
« Reply #11 on: August 12, 2016, 07:44:20 AM »
Looks normal to me. The only wear part I've seen on those is that the inside of the locking lug may try to round (it won't all the way, but it will develop a play in it) where it locks on to the actual stand shaft. If that's the case, you can always get a new beefier one.
http://www.mgcycle.com/index.php?main_page=product_info&cPath=73&products_id=371
Some of the later models, Convert, G5 have a tab as part of that piece that activates the side stand safety switch.
As far as the spinny-tube goes... beats me. I think it's there to prevent the tip from wearing over time, or maybe helps it from not catching when lowering the bike on the stand.
Take the stand off to inspect the lock and shaft it if that makes you feel better. I know it did for me.
« Last Edit: August 12, 2016, 07:47:57 AM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline brightonguzzi
« Reply #12 on: August 12, 2016, 07:57:26 AM »
Is that Brown stand a straight bolt on or do you need to fabricate any parts to make it fit?
Any idea how I can get one in the UK?
Le Mans V Special
Moto Guzzi Club GB member 2005
« Reply #13 on: August 12, 2016, 08:10:20 AM »
I worked with the guys at Boxerworks to develop the modified Brown for Guzzi Tonti frames.  The prototype is on my V7 Sport.  It's bolt on.  You need to remove the exhaust and run the rear engine mount through the tranny from right to left.  Same for the laft center stand bolt.  Each gets threaded into the mounting plate on the stand.  I did a photo tutorial of my installation if you search this forum.  They're expensive, but so is your bike's bodywork.  Piece of mind!
Offline swooshdave
« Reply #14 on: August 12, 2016, 11:09:24 AM »
Was this stand welded onto the bike or did the PO just replace a lower frame rail from a Police T3?
2001 V11 Sport
« Reply #15 on: August 12, 2016, 12:10:02 PM »
 No, my motorcycles never fall over, even when parked.
Offline swooshdave
« Reply #16 on: August 12, 2016, 12:45:11 PM »
Yes, but they are so big with the sidecar don't you need a reverse gear?
2001 V11 Sport
