Author Topic: V11 sport hugger removal  (Read 2070 times)
Offline oranges3
  • "this amp goes to eleven..." Nigel Tufnel, Spinal Tap
« on: August 15, 2016, 07:55:04 AM »
While doing a tail tidy on my v11 café sport, I decided to remove the hugger and plastic bits that cover the swing arm...
the swing arm looks great!!
Anyone else do this bit of modding?
2012 ducati diavel
1995 Triumph Speed Triple
1998 Triumph Thunderbird Sport
2004 V11 Cafe Sport
1999 Confederate America GT
2018 Motus MST
2007 griso
1986 kawasaki ninja 600r
ponti_33609
Re: V11 sport hugger removal
« Reply #1 on: August 15, 2016, 07:58:15 AM »
While doing a tail tidy on my v11 caf� sport, I decided to remove the hugger and plastic bits that cover the swing arm...
Years back...agree, the hugger was horrible.
« Reply #2 on: August 15, 2016, 08:01:20 AM »
I rode mine in all weather, and was glad to have the hugger.  Got plenty of road grime and grit all over everything as it was.
Offline Scud
« Reply #3 on: August 15, 2016, 09:33:39 AM »
The open swingarm does look cool.  I replaced both of my huggers with small carbon fiber inner fenders from Ghezzi-Brian (which allow a full view of the swingarm. I wouldn't run a totally open wheel, because I don't want to coat the shock with grit and grime.
The GB fender, while smaller than the plastic hugger, protects the shock more. The OEM hugger fits above the lower shock bolt and funnels the road spray up into it. The GB unit is not perfect, and takes a little more work to fit than other options, but once it's in you don't have to remove it to get the wheel out. (the belly pan is also from GB)
1989 Moto Guzzi LeMans
2017 Husqvarna 701 Enduro
2017 Moto Guzzi Stelvio NTX
2020 Yamaha TW200
Offline lucky phil
« Reply #4 on: August 16, 2016, 06:49:26 AM »
I find all GB stuff very overpriced and for mine a rear hugger should run in much closer proximity to the rear tire. The GB unit looks like it should be on a dirt bike.
Quality looks nice though.
Ciao
« Last Edit: August 16, 2016, 06:50:22 AM by lucky phil »
Offline Scud
« Reply #5 on: August 16, 2016, 08:30:04 AM »
The GB bits weren't cheap - but the $US dollar has been pretty strong compared to the Euro lately, so the price seems fair in $US. Might be different elsewhere.
I agree that it rides a bit too high over the rear wheel. In fact, I've been thinking about cutting (probably sanding actually) a relief in the fender where it comes close to touching the swingarm - then I could position it lower over the wheel. Will probably do that with next tire change.
2020 Yamaha TW200
