Author Topic: 850T Tank Part Mystery  (Read 4857 times)
Offline swooshdave
« on: August 17, 2016, 12:56:37 PM »
I notice this "thing" under the tank. There no wires coming from it. I don't think it measures fuel level. There no reason for a drain. What is it?
2001 V11 Sport
Re: 850T Tank Part Mystery
« Reply #1 on: August 17, 2016, 01:03:47 PM »
Maybe the tank is off of a Convert. Convert had a fuel level sender in that location.
« Reply #2 on: August 17, 2016, 01:55:47 PM »
Yep, that's what it looks like.
Online rodekyll
« Reply #3 on: August 17, 2016, 03:18:53 PM »
Yes, fuel light sender.  Wire terminals are recessed In the little collar.
Offline swooshdave
« Reply #4 on: August 17, 2016, 03:21:21 PM »
Was it just a light that went on to tell you that you were low?
2001 V11 Sport
Offline atavar
« Reply #5 on: August 17, 2016, 03:27:19 PM »
On my G5 the light went on and it dropped the fuel gauge to the bottom to incentivate you to get gas.
Online rodekyll
« Reply #6 on: August 17, 2016, 03:29:55 PM »
No, the engine would also backfire and stop.    :grin:
Offline swooshdave
« Reply #7 on: August 17, 2016, 04:25:00 PM »
Since there are no surviving Converts there'll be no way to know how to wire up a light to the thingy on the tank and make it work.  :popcorn:
2001 V11 Sport
« Reply #8 on: August 17, 2016, 04:41:51 PM »
You're kidding, right? Plenty of fully functional Converts out there. Plus, it was also used on G5s IIRC. The Convert wiring diagram would show how to wire it up as well.
IMO, it's not worth the trouble - it probably won't work right anyway. Many times the float fills with gas and then the light is on all of the time. Sometimes the contacts get dirty and the light doesn't come on at all. Converts came with an electrovalve on the left side, so I guess the warning light was to tell you to expect to have to turn the right-side "reserve" petcock on at any time. Your T likely has two petcocks with reserve positions (or can be made that way inexpensively), so there's really no need for a low fuel light.
I'd remove it and plug the hole:
http://www.thisoldtractor.com/moto_guzzi_tonti_fuel_level_sensor_plug.html
Offline Groover
    • Scooteropolis
« Reply #9 on: August 17, 2016, 04:43:36 PM »
Greg Bender may be able to create something for you...
http://www.thisoldtractor.com/for_sale_wiring_harness_tonti_v1000_i_convert.html
Also, on the same page he has those dual terminal bulb holder you need for the LEDs on your dash.
« Last Edit: August 17, 2016, 04:45:09 PM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #10 on: August 17, 2016, 05:19:26 PM »
 :1: on plugging it.  Not needed.
Offline swooshdave
« Reply #11 on: August 17, 2016, 06:36:42 PM »
Yes, I was kidding about the surviving Converts.  :violent1:
Yes, I have two taps with reserves on each. And honestly with a tank that size is there really an excuse for running down to reserve? (Joking again)  :rolleyes:
2001 V11 Sport
Offline swooshdave
« Reply #12 on: August 17, 2016, 08:05:22 PM »
Why do you need to plug it? Can it leak?
2001 V11 Sport
« Reply #13 on: August 17, 2016, 08:46:39 PM »
The sender is made of plastic, so yes, it could potentially leak. I've seen two that cracked along the edge and began leaking.
Offline lazlokovacs
« Reply #14 on: August 20, 2016, 12:05:33 PM »
this is a timely thread...
I just recieved an old footnall shaped tonti tank, mine has the hole and no sender... obviously it needs plugging. Greg's links are helpful... but this particular one leads nowhere... anyone got the thread sizes?
cheers as ever,
« Reply #15 on: August 20, 2016, 03:06:09 PM »
cheers as ever,
?? Link takes me right to a source with part no.
Thanks to Wayne Guntzel for sourcing this plug with the correct thread size and pitch as a suitable replacement for the original fuel level sensor.
Plug: New Holland / Case IH part number 10278301
Copper crush washer: New Holland / Case IH part number 10282260
Offline lazlokovacs
« Reply #16 on: August 21, 2016, 03:21:18 AM »
agreed,
and then searching the part number on either site leads to 'no results for this search'.....
Offline lazlokovacs
« Reply #17 on: August 21, 2016, 03:51:06 AM »
hey charlie, don't worry I've found it, and close to home...
OP, sorry for the thread hijack
....as you were gents....
Offline chuck peterson
« Reply #18 on: August 21, 2016, 05:32:44 AM »
Ummmm....Italian electrics wiring the gas tank to make a bomb....no, don't do that :drool:
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #19 on: August 21, 2016, 04:34:43 PM »
  It is just the detonator, pay it no mind and hope that it doesn't work.
Offline swooshdave
« Reply #20 on: August 21, 2016, 05:01:21 PM »
No wonder there are no surviving Converts!  :boozing:
2001 V11 Sport
« Reply #21 on: August 21, 2016, 06:16:42 PM »
Italian electrics? Not to worry.  :smiley:
That said, the low fuel sender was just a float that either was on or off. As the fuel level lowered, the light would flash on and off as the fuel sloshed around in the tank.. a royal PITA.
Offline Rich A
« Reply #22 on: August 21, 2016, 06:32:50 PM »
Curiously, the fuel sensor on my convert still works. But thanks for the info--I get a plug in anticipation for when it fails.
Rich
