Author Topic: Gasoline thread........  (Read 7961 times)
beetle
Re: Gasoline thread........
« Reply #30 on: August 20, 2016, 11:32:29 PM »
To the last, I grapple with thee; from hell's heart, I stab at thee; for hate's sake, I spit my last breath at thee. Die thread, die.
« Reply #31 on: August 21, 2016, 03:56:00 AM »
 :grin:
Offline Two Checks
« Reply #32 on: August 21, 2016, 07:00:47 AM »
Actually octane does not make the fuel harder to ignite, it raises the temperature at witch it AUTOignites.
Higher the octane the more the air/fuel mixture can be compressed before it explodes by itself, causing pre-ignition, wich caused detonaton, or pinging or pinking to our friends across the pond.
1987 1000 SPII "Il Duce' II"
Offline Nic in Western NYS
« Reply #33 on: August 21, 2016, 07:24:28 AM »
Non ethanol in anything other than 87 is unavailable to Tom , thus the question . Better to deal with some side effects of ethanol than the effects of pre ignition .
That's the heart of the matter.  In looking around the internets for the effect of using octane boosters to allow for use 87 (regular, not premium) non-ethanol gas in engines that require premium, the problem is the meager octane improvement that results from use of the additives.  So, while theoretically you can use regular non-ethanol gas and increase the octane through an additive, the effect is inadequate when using the products as recommended. No more gas posts for me for at least 5 years.
'04 Ducati ST4sABS
« Reply #34 on: August 21, 2016, 02:00:17 PM »
Thanks for the advice. :thumb:  I run the highest octane rating available for the older Guzzis.
Offline Farmer Dan
« Reply #35 on: August 21, 2016, 02:46:51 PM »
every station in town sells nothing but E-10 so I run the 87 octane in my Eldo.  If I have it figured right 87 is equal to 91 in the old RON method.  Anyway only problems I've had so far is keeping bugs off my windshield.  Knock on wood.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
