Author Topic: Moto Guzzi 80's era fairing plastic.  (Read 2688 times)
Online sdcr
« on: August 25, 2016, 01:19:52 PM »
  My fairing on the Le Mans III is constructed of some type of plastic. it may  be ABS, or something similar. I noticed a stress crack along the bottom, near the center mounting hole.
  I want to use an adhesive to repair it, and would like to hear from some other who found a product that works well on this type of material.
   I have tried JB weld, which usually fixes anything, but it did not adhere to the surface area, once it cured.
Any suggestions n a specific product?
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline Groover
    • Scooteropolis
Re: Moto Guzzi 80's era fairing plastic.
« Reply #1 on: August 25, 2016, 01:27:26 PM »
I would use epoxy, but combined with fiberglass cloth. Basically brush epoxy, then a layer the fiberglass cloth, repeat until you have a nice sturdy looking repair.
Fiberglass cloth can be found at hobby stores (R/C hobby, not crafts) and comes in different strengths usually the coarser the weave, the higher the rating. The fiberglass cloth will "melt" into the epoxy. Once all is dried, sand it until you're happy with the results.
Good luck.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline pehayes
« Reply #2 on: August 25, 2016, 01:27:40 PM »
Yes, it is likely ABS.  Vetter used to sell a "hotcha" kit for repair to their ABS fairings.  You can get ABS glue and small bits of sheet plastic for repairs at a good hardware store or plastic supply like TAP.
Offline rboe
« Reply #3 on: August 25, 2016, 03:22:05 PM »
My Quota had black plastic tupperware and most bits had cracks. Thinking it was ABS I used ABS cement for plumbing pipe that I had laying around. This worked on the side cases but not on the front fairing. Different plastic. That was an eye opener!
By the way, the ABS glue worked great and I reused it recently on an OLD Pacifico top case that fell into my hands.
Phoenix, AZ
2008 Honda XR650L
2012 Griso SE
2013 Honda CB1100
Offline Matt Story
  • Flint, MI
« Reply #4 on: August 25, 2016, 04:05:13 PM »
If ABS, I have learned the following from printing 3D models in ABS.  Acetone used in very small amounts will marginally melt adjacent surfaces (like a crack)  and result in a surface bond.  You might brush it on the crack from the inside of the fairing with a model brush.  I mean a very small volume.  Capillary action will draw it into the crack and create the bond.  Hold it for a few minutes.  My understanding is that the acetone melts the 2 halves so they can bond, and then evaporates.  You might want to follow up with a lap of fiberglass or epoxy on the inside for reinforcement.  May be worth trying.  Please try first in a small inconspicuous place.
Matt
'75 850T - First & only owner
'77 Honda CB750 Supersport
'02 BMW R1150RT
Flint, MI
Offline swooshdave
« Reply #5 on: August 25, 2016, 04:14:55 PM »
Matt
I don't think you'll need to reinforce at all. You may find the bond from the acetone stronger than the surrounding ABS.
2001 V11 Sport
Offline bigbikerrick
« Reply #6 on: August 25, 2016, 04:15:05 PM »
Polyvance is the company that  I have found has the best products for professional plastic repair. I have been using their products for many years. their "flex filler" is what you want to use. It is a 2 part epoxy. It will stick tomost anything that is properly prepped. Its great stuff.
http://www.polyvance.com/Flex-Filler-1/2000-T/
Rick
Offline Matt Story
  • Flint, MI
« Reply #7 on: August 25, 2016, 04:23:48 PM »
Another glue I have used on printed ABS parts is PVC/ABS pipe cement.  Beware that this is much more aggressive in its melt capability.
'02 BMW R1150RT
Flint, MI
Online sdcr
« Reply #8 on: August 25, 2016, 05:55:28 PM »
Matt
H
 Matt,
This sounds like a worthwhile try. One of my riding buds also suggest trying something called Q-Bond. It's a two part epoxy that contains reinforcing powders.
Thanks to all for the good suggestions.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
