Author Topic: 07 Norge oil temp thermostat  (Read 4610 times)
« on: August 27, 2016, 07:57:21 PM »
Does my '07 Norge have a oil TEMPERATURE thermostat ?
« Last Edit: August 27, 2016, 08:09:52 PM by Huzo »
Offline MAC
Re: 07 Norge oil temp thermostat
« Reply #1 on: August 27, 2016, 08:23:33 PM »
Yes, inboard the right cylinder.Check for broken sensor support.
Oil temperature sensor part#29729461
Sensor support part#03163330
http://www.harpermoto.com/parts-by-motorcycle/2000-up-moto-guzzi-motorcycles/norge-1200-ie-1200-2006-2008/electrical-system-i-en-norge-1200-ie-2006-2008.html
« Last Edit: August 27, 2016, 08:26:00 PM by MAC »
Mike Cignarella
1998 EV
2008 Wing
2015 K1600GT
Offline Bisbonian
  • Living the Dream
« Reply #2 on: August 27, 2016, 11:23:58 PM »
Sensor and thermostat are two different things.
I don't think the 2 valve engines have a thermostat.
Not 100% sure though.
« Reply #3 on: August 28, 2016, 12:37:18 AM »
Yes the diagram shows part# 25 as oil temp sensor, but as far as I can tell no pressure sensor., however I know the pressure sensor exists 'cos I've replaced it once and it comes on before start up and immediately goes out when running, there's been a lot said about them here. Also where does the air temp sensor mount ? Mine has always sorta just hung on the harness inside the fairing. There's nothing amiss, just wondered. Thanks, Huzo.
Offline Phang
« Reply #4 on: August 28, 2016, 02:57:54 AM »
2V Norge has a oil thermostat
Part #5 in the diagram
2000 V11 Sport (Green)
1973 V7 Sport (Green)
« Reply #5 on: August 28, 2016, 04:52:45 AM »
Phang nails it! (Greetings from Ireland my friend!)
« Reply #6 on: August 28, 2016, 12:47:32 PM »
Yep, nailed it indeed! Thanks Phang and Peter.
Offline tris
« Reply #7 on: August 28, 2016, 02:30:58 PM »
....... Also where does the air temp sensor mount ? ......
If its the same as my Breva the ECU air temperature sensor mounts into the air box on the right side
1993 TW125 "POS" - Resting
Offline Idontwantapickle
« Reply #8 on: August 28, 2016, 02:55:29 PM »
I think you are describing the ambient air temp sensor for the dash display.
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
« Reply #9 on: August 29, 2016, 01:13:46 AM »
Hunter
Bingo !!!! Any ideas ?
Online rodekyll
« Reply #10 on: August 29, 2016, 03:16:07 AM »
It just needs to be in the air somewhere, preferably not too close to the engine.  Where doesn't really matter to the sensor, as long as it can measure outside air.  If it bothers you hanging there, zip tie it or thread it around to somewhere else.
As to the 'proper' place -- don't know.
Offline tris
« Reply #11 on: August 29, 2016, 02:10:04 PM »
Doh - answered the wrong question  :embarrassed:
The dash temp sensor is mounted at the left hand end of the little panel that carries the 4 way flashers and ABS switches
Offline ITSec
« Reply #12 on: August 29, 2016, 04:07:08 PM »
I may be wrong (happens at least once every few years), but that part looks an awful lot like an oil pressure valve and not a thermostat. I know how it's labeled in the parts diagram, but this is from a company that still has trouble identifying a transmission in a manner that most people understand.  :laugh:
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
« Reply #13 on: August 29, 2016, 04:11:38 PM »
Nope, it's the thermo. The OPRV is next to it
« Reply #14 on: August 30, 2016, 01:21:46 AM »
Yeah reasonable comment, I just couldn't find an appropriate spot within the range of the harness. But thanks for the help.
