Author Topic: Need help, need parts ASAP.  (Read 4739 times)
Offline Toecutter
« on: August 29, 2016, 02:24:19 PM »
Coles notes version:
My wife has spent a LOT of time planning a trip for us and my buddy, routes, stays, everything, from top to bottom, going as far as to schedule my vacation time with my boss. My buddy has rearranged his holiday plans to make it happen. We're set to leave this Friday morning.
...and I've blown a base gasket on my '15 V7 Special.
I desperately need parts #:
B063099  Head/cylinder packing
886670  Crankcase/ cylinder packing
And I need them over-nighted to me, by the fastest carrier possible. Can someone suggest a vendor that can meet my needs? Please... it'll break her heart if we have to cancel this.
Thank you.
Offline Trogladyte
  • Location: South London - home of the world's best football team.
Re: Need help, need parts ASAP.
« Reply #1 on: August 29, 2016, 02:30:50 PM »
Knowing your location could be a start.
Offline Toecutter
« Reply #2 on: August 29, 2016, 02:37:06 PM »
Acheson, Alberta.
Offline stevet
« Reply #3 on: August 29, 2016, 02:46:42 PM »
AF1 Racing, a Guzzi parts dealer in Austin, TX, has both of those parts in stock.  $17.11 for one, $11.27 for the other, US dollars.  Enter you part number in the part number search box at the top of this page, you will see them.  Then call the shop, maybe they can get them out the door today and into your hands ASAP.  And if I were you, I'd order 2 of each, because I would screw up at least one of them somehow!!
http://af1racing.com/store/Scripts/default.asp
Good luck!
Steve.
Steve T.
Twin Cities, MN
Feejer, '10 Yamaha FJR
-George Eastman.
« Reply #4 on: August 29, 2016, 02:46:58 PM »
Harper's?
http://www.harpermoto.com/product-14948.html $10.04
http://www.harpermoto.com/head-cylinder-packing-b063099.html $15.26
Do call to make sure they're actually in stock.
« Last Edit: August 29, 2016, 02:48:51 PM by Antietam Classic Cycle »
« Reply #5 on: August 29, 2016, 02:50:30 PM »
If you explain the circumstances, any U. S. dealer can overnight.  Moto International was able to send parts to me at John Day, the last time there was National there.
Offline stevet
« Reply #6 on: August 29, 2016, 02:53:24 PM »
More-
Moto International in Seattle is probably closer to you than any so far, call them, see if they have parts in stock.
http://www.motointernational.com/
MG Cycle showed the first one, but not the second part.  www.mgcycle.com/  South central Wisconsin.
Steve.
« Last Edit: August 29, 2016, 02:54:28 PM by stevet »
Steve T.
Twin Cities, MN
-George Eastman.
Offline Daniel Kalal
  • Daytona, Stelvio [Kansas]
    • Trip Reports
« Reply #7 on: August 29, 2016, 03:19:49 PM »
Acheson, Alberta.
That's Edmonton, isn't it?  There's a dealer there (or at least there is one on record):
Echo Cycle LTD
15311-118 Avenue
Edmonton
T5V 1C3
Offline ITSec
« Reply #8 on: August 29, 2016, 03:59:49 PM »
If you are ordering from the US to Canada, make sure you DO NOT use UPS. Their customs clearance process is all in Winnipeg and takes at least an extra day or two compared to FedEx or other carriers.
I lived in Edmonton (Mount Pleasant area, mostly) for more than 25 years and found this out (repeatedly) over the years.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline Toecutter
« Reply #9 on: August 29, 2016, 04:11:35 PM »
I've taken a scattergun approach... ordered from Guzzitech  and AF1.
Scheduled to arrive Wednesday, but I've got my doubts. Fingers crossed.
Thanks all.
« Reply #10 on: August 29, 2016, 05:21:37 PM »
how did that happen ?
Offline O
« Reply #11 on: August 29, 2016, 06:37:59 PM »
Indeed, do tell.
Owen
2014 V7 Special
Offline lucky phil
« Reply #12 on: August 29, 2016, 10:26:40 PM »
Base gasket or leaking breather? I'm betting its not the gasket.
Ciao
Offline Toecutter
« Reply #13 on: August 30, 2016, 09:10:08 AM »
I'll take that bet.
The base gasket on the left side is blown. My bike, my eyes, on the lift, mechanic to back me up... base gasket is blown.
How? I don't know. But it's leaking oil and getting worse, rapidly. Gone from a slight weep to a full on leak.
« Last Edit: August 30, 2016, 09:10:52 AM by Toecutter »
Offline atavar
« Reply #14 on: August 30, 2016, 10:47:33 AM »
Chiming in just to make sure I don't miss the final diagnosis of this.  It will be interesting to hear what could happen to cause an undisturbed base gasket to blow.  Shouldn't be much pressure there and the thing is clamped rather securely in place.
I believe you, I am just curious as to what could make this happen.
Offline Toecutter
« Reply #15 on: August 30, 2016, 10:51:56 AM »
I'm with you. All I can think is a faulty gasket, though why it would appear at around 17,000 km makes no sense to me.
Offline atavar
« Reply #16 on: August 30, 2016, 11:59:30 AM »
Base gaskets are rather simple and could be hand cut from like thickness generic gasket material if necessary, yes?
« Reply #17 on: August 30, 2016, 12:13:58 PM »
Not if you don't want it to leak. I believe the's an o-ring required as well if you're tugging the barrel.
Offline lucky phil
« Reply #18 on: August 31, 2016, 02:51:06 AM »
I'll take that bet.
Well the last "base gasket" leak I saw on a Guzzi turned out to be crankcase porosity. When you say "blown" does that mean a piece of the gasket has come adrift and is missing/displaced?
Ciao
« Reply #19 on: August 31, 2016, 06:01:11 AM »
I have to say I'm deeply skeptical about the base gasket theory as well but the OP seems certain. Thing is if the heads hadn't been retorqued early on and a gasket started to weep I'd honestly expect it to be a head rather than a base gasket that would cause issues....
Good luck.
