The pump is upstream of the filter. So if you run out of gas you suck crud into the screen of the pump. This can plug the pump intake. Also, when you run completely out of gas you can have a violent backfire, which can blow off throttle bodies and exhaust bits. We get that reported here occasionally.
Oh No! Side effects may include dizziness, blurred vision, burping, swelling, sudden gas discharges, loss of nose and ear hairs, diarrhea, shortness of breath and sudden temper fits!Remember!!! - observe polarity when replacing fuel pump lines.
Sorry but I cant see one single piece of accurate information in this post. As for pump overheating issues, well as Pete rightly pointed out if the engine isnt running then neither is the pump, so no issue.I've run out of fuel several times on the V11 Sport. Long down hill engine cuts out, roll to the bottom of the hill and hit the rise, engine fires up again. Repeat.Never an issue, except for the pushing at the end.Ciao
Phil, I generally defer to your greater experience, but I'll take the opposite side here. I've got an external system here from older EFI that the OP's bike uses that has the flow go supply - fuel pump - filter. I've got an internal one (that seems fairly universal in the later bikes -- the kind the hose pops off of inside the tank) and it also goes supply - pump - filter - and then external connector. Neither has the filter ahead of the pump. At least the external type had an additional chunk catcher at the petcock. With the internal type, the pump is a chunk's first encounter.The bosch design has a built-in screen behind the intake barb. It's in the specs. The same design (same part number in some cases) has been used in fuel injection since the 70s, and they've all had them. One trick we use to clear that screen is reversing the polarity and backflushing the pump. There are topics here about that all the time.Likewise, we have frequent topics about backfires blowing off throttle bodies. Backfires are commonly associated with running out of gas. I've had backfires when that happened severe enough to strip the drivepiece in my Convert fluid pump.So I'd say in the context of "what can happen when an efi bike runs completely out of gas", every piece of information in that post is both realistic and verifiable.
You run your efi bike (lets say 98 EV) completely out of gas? I have heard there can be problems with the fuel pump if this happens, especially if the pump is an 'in the tank' type that is cooled by the gasoline.
It would seem strange to me that a vehicle would be designed such that something as likely as potentially running out of gas would damage it.It would be like having a bike where, if you hit the starter button going down the road, that the starter would engage and destroy the flywheel. Or that your airplane would have a "Wings Fall Off" switch right next to the headset stereo volume like Gary Larsen did.Running out of gas isn't like running out of oil or transmission fluid. It's something that can happen on a long trip in a big country; the bike is DESIGNED such that it will run out of gas every few hours. Can it be that, if you forget and run it all the way down, you'll burn up your pump or something?As if your entire electrical system would short out if you left your turn signal on too long. Yes, I know you're SUPPOSED to turn your turn signal off, but what if you just forget?What were they thinking? Or is it really not an issue?Lannis
Holy crap.The bike stops, and you start walking or pushing. No harm. Case closed.
Well, unless you are in the left lane of a heavily traveled urban interstate, with a truck right next to you on the right, an SUV running up your rear end, no shoulder on either side ....... and your bike quits. That doesn't seem very good; matter of fact, could be harmful.Lannis
