Author Topic: How to remove carbs? On Eldo.  (Read 1732 times)
Offline motogman
« on: August 31, 2016, 07:17:07 PM »
I will post some pictures later but those of you that have done this will know what I am asking...
I am working on a 74 Eldo I just picked up and have loosened the clamp ring that holds the carbs (Delorto VHB 29s) onto the intake stack.  One I can barely rotate and was not able to make progress towards it''s removal.  The other I stopped screwing with until I can get some recommendations on how to get these loosened up without hurting them or myself.   :evil:   :laugh:   :grin:
Re: How to remove carbs? On Eldo.
« Reply #1 on: August 31, 2016, 07:27:08 PM »
I use a hardwood dowel - place it up against the carb body (at the inlet, not up against the square section or anywhere else) and bonk it with a hammer. Alternate between the top and bottom, driving it off of the manifold a little at a time.
Apply a little anti-seize on the plastic sleeve in the carb and on the manifold stub before installing. That'll make it much easier to remove next time.
« Last Edit: August 31, 2016, 07:30:21 PM by Antietam Classic Cycle »
« Reply #2 on: September 01, 2016, 12:06:27 AM »
 :1: :1: :1:
One thing not mentioned. Rotate the carb so the fuel bowl sits a bit outward. If you don't, one or both will hit the trans/engine case before sliding off if I remember correctly.
Another option when you install them, good old white lithium grease works fine. Just wipe a bit in the carb side them slide over the manifold. Just use enough to wet the surface.
« Last Edit: September 01, 2016, 06:31:35 PM by Tom H »
Offline v7john
    • The Racing Rhino
« Reply #3 on: September 01, 2016, 04:44:18 AM »
I've just taken mine off complete with the intake. I started hitting it like Charlie said but didn't want to end up pounding it with a club hammer and the veins sticking out on my forehead!
https://racingrhino.wordpress.com/2016/08/28/flooding-28-aug-2016/
1954 BSA M33 500cc.
