Author Topic: Guzzidiag help-Bricked ECU  (Read 6856 times)
redrider
« on: September 03, 2016, 05:29:47 PM »
Attempted to load another map on the 04 Café Sport. (LeMans MY02) All indications good through verify no fuel pump. Dialog box appears-Not a file type saved but it's your decision. Click OK-nothing. No start, crank ok. no fuel pump run.
Online pauldaytona
    • Paul's fast Guzzi Page
Re: Guzzidiag help-Bricked ECU
« Reply #1 on: September 03, 2016, 05:42:51 PM »
Looks you tried to load something that is not a map on it. So it might be errased, try again with a good map. Like the first one you saved from it.
Paul
Daytona 1225, Stelvio 1151
Offline sib
« Reply #2 on: September 03, 2016, 05:43:58 PM »
Consider this to be an expensive lesson, on-the-job training in ECU programming.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Online pauldaytona
« Reply #3 on: September 03, 2016, 05:59:07 PM »
normally with writing a log file is generated, please post contents here. You also can see what file you have been using.
Paul
redrider
« Reply #4 on: September 03, 2016, 06:05:38 PM »
Thanks Paul. I had saved the maps you sent and actually tried several of them before using the Ti one for the last 18 moths. I'll try the original on the hard drive but it was odd that the previous trials all loaded with no difficulty but now they do not. The only thing different is that I have used guzzi diag and tunerpro to compare maps. No change of map data was ever done though.
Online pauldaytona
« Reply #5 on: September 03, 2016, 07:20:14 PM »
 please the put here the log file.
Paul
beetle
« Reply #6 on: September 03, 2016, 08:28:05 PM »
You can't brick an ECU with GuzziDiag. I don't think I've ever seen you post anything positive. :rolleyes:
« Reply #7 on: September 04, 2016, 01:52:11 AM »
He's just taking five minutes out from working out how to save five bucks on his phone plan or make a profit from being in debt. Don't worry about it, one day he may make a friend!
redrider
« Reply #8 on: September 04, 2016, 11:30:57 AM »
Mission Control has re-established communication with the AI Device. Seems that the socket for fuse 1 was somehow tweaked, perhaps when I removed the fuse cover to disable the headlight, and was not supplying power to the AID(CPU). Thanks for the help for a self induced trauma drama.
redrider
« Reply #9 on: September 04, 2016, 03:51:02 PM »
Bump
Online pauldaytona
« Reply #10 on: September 04, 2016, 04:29:10 PM »
Bump?
I thought problem solved, you a driving again?
Paul
redrider
« Reply #11 on: September 04, 2016, 05:02:27 PM »
All is well. Slight CO trim and Idle adjust. Two beers down, no riding.
Offline craigclu
« Reply #12 on: September 04, 2016, 11:11:40 PM »
I had a similar scare recently.  A bit unsettling but a circle of candles and some incense had me square again.  Glad you're back on track!
He who is without oil shall cast out the first rod...”-Detonations 5:72.
Offline sib
« Reply #13 on: September 07, 2016, 06:43:10 AM »
.....I don't think I've ever seen you post anything positive. :rolleyes:
Possibly because you've been too busy selling useless snake oil ECU remedies to unsuspecting folks here.  Overall, I think I've contributed as much to this forum as you, despite my occasional sarcasm.
« Last Edit: September 07, 2016, 06:44:26 AM by sib »
« Reply #14 on: September 07, 2016, 09:53:17 AM »
Sib, you're being unfair.  Beetle and a very small corps of others are putting a genuine effort into improving moto guzzi.  Undermining the effort with this baseless bickering isn't helping his/their effort, and rather belies your claim of also contributing, on account of tearing down someone elses's work is not a contribution.
redrider
« Reply #15 on: September 07, 2016, 10:28:00 AM »
And the rush to judgment did not pan out, either. I "slept on it", applied a bit of reasoning and despite the gloom and doom forecast, persevered. Again, thanks to all who offered assistance with a well engineered product.
« Reply #16 on: September 07, 2016, 10:31:59 AM »
 GEEZ-O-PETE !
beetle
« Reply #17 on: September 09, 2016, 04:41:06 AM »
:grin:
