Author Topic: My first time doing a valve adjustment on 2 V 1200 Sport ... question  (Read 3574 times)
Offline willowstreetguzziguy
I do not have a center stand so I will need to turn the engine at the front. Does it rotate clockwise? If it does, is it bad to rotate it against the normal direct to get the engine at TDC?
2008 Guzzi 1200 Sport
Re: My first time doing a valve adjustment on 2 V 1200 Sport ... question
« Reply #1 on: September 05, 2016, 09:34:27 AM »
yes, clockwise.. probably not a good idea to rotate in reverse..
« Reply #2 on: September 05, 2016, 10:02:30 AM »
I think the only reason not to go backwards is sometimes it will loosen the nut.
« Reply #3 on: September 05, 2016, 11:21:56 AM »
What size is the metric nut at the front to turn the engine?
« Reply #4 on: September 05, 2016, 12:01:51 PM »
it's a 24mm
Offline Waltr
    • Europa Macchina
« Reply #5 on: September 05, 2016, 06:40:02 PM »
Or 1 inch will do fine.
www.motoguzzipa.com
2012 Norge
« Reply #6 on: September 05, 2016, 08:02:36 PM »
I did my Centauro for years by rolling it forward in fifth gear. Never did use the nut on the front. Too much work to remove the cover.
« Reply #7 on: September 05, 2016, 08:46:47 PM »
All went well. The exhaust valves were dead on at .006" but the intake valves were at.005" and I set them back to .004". A fairly easy job. A YouTube video on a Norge helped as well.
Offline derek533
« Reply #8 on: September 05, 2016, 11:43:59 PM »
Ok, so I've never done my own valve jobs before (except on a Briggs lawnmower motor) but that was one of the things that attracted me to the Guzzi in the first place since it appears to be a fairly straightforward process due to the ease of access.
One question for my infantile mechanical mind, what is the purpose of putting the bike in high gear?
06 Breva 1100
Married, 3.5 kids, and very blessed.
Offline ITSec
« Reply #9 on: September 05, 2016, 11:49:31 PM »
I haven't looked at the cover of a Centauro, but on most Guzzis of recent years there's a rubber plug up there. When did that start?
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline ITSec
« Reply #10 on: September 05, 2016, 11:50:51 PM »
Fifth gear means the engine turns more slowly compared to the rear wheel. It allows you to turn the crank more slowly, and be more accurate about hitting the intended position.
ITSecurity
