Author Topic: Yamaha Based 14 Cylinder Radial Engine  (Read 6904 times)
Hymes Inc.
Re: Yamaha Based 14 Cylinder Radial Engine
« Reply #1 on: September 14, 2016, 11:31:13 AM »
Look at those jugs!  :drool:
Offline ITSec
« Reply #2 on: September 14, 2016, 02:22:17 PM »
My first thought was that this could replace a Double Wasp - then I saw that central casting! There is way too much metal there, beautifully machined though it is, to use this in anything that gets off the ground. It may have 11.9 litres of displacement, but at only 50HP per cylinder output (I think he said) it just doesn't have the power-to-weight ratio. He mentioned using it in an airboat, which might work - but put some ballast forward!
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline acogoff
« Reply #3 on: September 14, 2016, 03:51:56 PM »
     I would cut the guy some slack, it is a prototype. Though I built and flew my own airplane, I never built my own engine, so I keep my mouth shut.
Marshall County Minnesota USA
« Reply #4 on: September 14, 2016, 04:10:52 PM »
I don't think he has any intention of using in an aircraft, only an airboat. I'm not qualified to critique his work - his skill set is waaaay beyond mine (and likely just about everyone else's here).
Offline clubman
« Reply #5 on: September 14, 2016, 05:11:25 PM »
The question is, where did he get all those parts? 7 large motorcycles worth of top end parts, plus one very large Al billet.
Offline trippah
« Reply #6 on: September 14, 2016, 05:29:25 PM »
Beautiful :bow:
Online rodekyll
« Reply #7 on: September 14, 2016, 10:57:24 PM »
a lot of Yamaha's woke up in a bathtub of ice with a note to call their mechanic.
Offline Phang
« Reply #8 on: September 15, 2016, 03:37:13 AM »
That's hilarious  :thumb:
2000 V11 Sport (Green)
1973 V7 Sport (Green)
Offline pete mcgee
« Reply #9 on: September 15, 2016, 03:50:35 AM »
He has eliminated at least 50% of potential oil leaks, where's the fun in that?
This is from the oil coated one working on R2000 m7.
IMO he would be better off with a supercharger rather than a turbo, but its his project and I wish him well.
Love his machining.
Offline bobdar
« Reply #10 on: September 15, 2016, 06:17:41 AM »
I guess we can call that a water brake dyno?
bob darcey
lakewood, colorado
'75 850T
'56 Matchless G80
Offline John Ulrich
Eagan, MN & Scottsdale, AZ
MN MGNOC Rep  L#800
Offline twhitaker
« Reply #12 on: September 23, 2016, 03:38:43 PM »
FWIW, that crankcase is not billet. It is cast. Take a look at the area around the tappet bores. Nice fillets and radii. Not what you would see if machined.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline swooshdave
« Reply #13 on: September 23, 2016, 05:54:41 PM »
Good catch. The "shroud" is machined, maybe from billet, maybe from a cast piece. Regardless that's a big chuck of metal to be machining on.
2001 V11 Sport
« Reply #14 on: September 23, 2016, 07:49:09 PM »
Radial engine in a motorcycle frame....
 :huh:
redrider
« Reply #15 on: September 23, 2016, 08:05:45 PM »
How about a Heron head V7 based 18 cylinder radial? If we just pool our resources....
Offline Murray
« Reply #16 on: September 23, 2016, 08:32:42 PM »
Put the most inefficient head design that Guzzi has inflicted on the public on something that needs a high output at low RPM. What could possibly go wrong?
Offline Aaron D.
« Reply #17 on: September 23, 2016, 09:01:47 PM »
Like the Merlin?
Offline swooshdave
« Reply #18 on: September 23, 2016, 09:40:58 PM »
 :huh:
2001 V11 Sport
Offline ITSec
« Reply #19 on: September 23, 2016, 10:31:16 PM »
What's the mileage like when you have more displacement than gas tank volume?  :evil:
ITSecurity
Doppelgaenger
« Reply #20 on: September 24, 2016, 01:05:05 AM »
https://www.youtube.com/watch?v=HADpy9bF2U4 You only need enough fuel to overheat it.
Offline tris
« Reply #21 on: September 24, 2016, 02:54:44 AM »
Nah - this is how to put a radial engine in a motorcycle
https://en.m.wikipedia.org/wiki/Mego
1993 TW125 "POS" - Resting
redrider
« Reply #22 on: September 24, 2016, 05:03:23 AM »
Was not the Heron head developed specifically for radial aircraft engines? Very efficient at moderate rpm but high revs expose the lack of adequate air flow. Not a problem with a 3k redline.
Offline Murray
« Reply #23 on: September 24, 2016, 05:42:11 AM »
I've seen the inside of a few aircraft engines I have never seen a Heron head. Far more likely to be used in mass produced Diesels as it makes the head simpler and stronger generally if your using diesel you don't give a rats about weight.
Offline Aaron D.
« Reply #24 on: September 24, 2016, 07:31:37 AM »
Again, the Merlin is a Heron design.
