AutoZone has a blind bearing puller for rent. $160 down and you get it back when the tool is returned. Best to use the Credit Card. And check for damage before leaving the store. You don't want to be left holding the back for the previous dolt. I have rented the tool three times now without incident. Made gearbox and wheel bearing removal a breeze
I wonder if you could take them out hydraulically like you can remove a clutch pilot bushing (on a car)? Pack the bottom of the hole with grease, and drive/press a slip-fit slug into the grease. Pressure differential caused by the different surface areas multiplies the force and pushes out the bearing... Heat first couldn't hurt. I don't know. Maybe worth a try. I've used it a couple times on blind fit plane bushings.
