Front Brakes
Topic: Front Brakes (Read 1318 times)
dave48
New Egg
Front Brakes
September 22, 2016, 12:17:59 PM »
I’m new to the forum. I recently acquired a 1975 850T and it needs front brake parts. I’ve searched FAQ but can’t determine what front caliper is stock. Is the stock front caliper an F08 or F09? The one I have has two bleed ports.
Also, what’s the difference between the 08 and 09? And are the parts interchangeable?
Thanks - Dave
Re: Front Brakes
Reply #1 on:
September 22, 2016, 12:21:47 PM »
8's, MG Cycle has parts and complete calipers. Unless you care about keeping the stock dual bleeder caliper I recommend buying a new caliper, hardly any difference in price by the time you replace the pistons, seals, clips and pads.
Antietam Classic Cycle
Happily stuck in the past.
Re: Front Brakes
Reply #2 on:
September 22, 2016, 12:31:53 PM »
The F08 is original, but if you still have the original 15 mm master cylinder, the F09 is a good upgrade for improved power and feel. With the F08, lever feel is very "wooden" and you need a very strong pull to achieve much braking at all.
The difference between the F08 and F09 is the piston diameter, 38 mm vs. 48 mm respectively.
Last Edit: September 22, 2016, 12:33:11 PM by Antietam Classic Cycle
Front Brakes
