Author Topic: Breva 1100 Front main seal installation questions  (Read 1096 times)
Offline LeakyLogic
« on: September 25, 2016, 07:35:11 PM »
I read the posts concerning how to remove and replace the front seal that fits into the timing cover. My question is this. How much oil, if any, should I drain before removing the seal? Also, what is the torque value for the crank nut? Lastly, did you lube the seal and with what?
Offline skippy
Re: Breva 1100 Front main seal installation questions
« Reply #1 on: September 25, 2016, 08:00:35 PM »
You don't have to drain any oil from the motor, it is all well below the level of the crank. I believe the torque for the pulley nut is 150 newton meters, which is about 110 foot pounds. A little bit of lubrication is a good thing. My preferred assembly lube is Lubriplate. But if you don't have any just dab some motor oil on the seal before you slide it in.
I am hoping some one might chime in and confirm the torque spec.
Skippy
23 V100 Mandello
20 V85TT
Offline LeakyLogic
« Reply #2 on: September 25, 2016, 08:16:19 PM »
Thanks.
What did you use to clean the area and was any sanding/polishing needed?
