Author Topic: Breva 750 crank but no start  (Read 4630 times)
Offline Jurgen
« on: October 02, 2016, 05:26:26 PM »
I need some ideas.  Put my 2004 Breva 750 away 2 weeks ago running until I turned off the ignition.  Ready to ride todayand it won't start.Turn on the ignition, the gages do their dance, the pump runs for 2 seconds, the starter cranks the engine but it won't start.  Tried several times and almost ran the battery down.
The facts are: 1. Fuel pump runs and gages dance
                     2. Fuel tank 3/4 full and no swirl during pump running
                     3. Plugs dry (but nice and grey), no smell of gas, and no hint of a spark (yes, they were grounded)
                     4. All fuses are OK
                     5. Starter turns over the engine
                     6. I have not removed an injector, but suspect no fuel is being injected
                     7. I have not checked any sensors, don't know where they are.  Is the crank position sensor on the front of the    engine case directly in front of the left cylinder?
                     8. Any suggestions would be welcome.  (BTW, I know what makes an engine run, but havn't got a clue about an ECU and what inputs it needs to make it work).
Jurgen
Jurgen
Re: Breva 750 crank but no start
« Reply #1 on: October 02, 2016, 05:32:00 PM »
 Sounds like another case of fuel filter or hose separation . Open the gas cap , and watch for swirling .
« Reply #2 on: October 02, 2016, 05:50:55 PM »
Yes, in front of LH cyl on top of case. Got a Workshop man? Here---
http://www.guzzitek.org/gb/ma_us_uk/750/Breva750IE_042003_Atel(GB).pdf
Check the relay's also the sidestand switch, clutch lever switch on LH lever perch on bars
Sidestand up & in neutral?
« Last Edit: October 02, 2016, 05:58:31 PM by guzzisteve »
Offline sign216
« Reply #3 on: October 02, 2016, 10:00:40 PM »
Are you sure there both no spark and no odor of fuel on the plugs?
That's odd.  Usually it's one or the other.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #4 on: October 03, 2016, 12:08:36 AM »
The pump primes when you turn the key ON
Does it re-start as the bike is cranking to indicate the ECU is getting pulses from the crank sensor?
It might be a little hard to hear the pump over the cranking but I suspect it should run for a second after
Sometimes it's hard to see a spark but if you grasp the plug in your hand and rest the same hand on the engine you will feel the spark as a tingle.
(don't ground any other part of your body)
« Last Edit: October 03, 2016, 12:14:34 AM by Kiwi_Roy »
« Reply #5 on: October 03, 2016, 09:10:59 AM »
It is worth your time to check the fuel filter...not a hard job and that way you will know for sure...
Offline Jurgen
« Reply #6 on: October 08, 2016, 02:01:07 PM »
Thanks Kiwi, After a few days of rest and putting the charger on the almost depleted battery, I put my ear to the tank while hitting the starter and sure enough, heard the pump run.  And about a second later, those nice exhaust notes of an awakening engine.  I think what the problem might have been was a low battery causing the ECU to shut down.  Therefore no spark or fuel.  That still doesn't explain why the fuel pump ran on turning the key since that signal also comes from the ECU (I think).  Anyway, I'm on the road again.  Jurgen
Jurgen
Offline timonbik
« Reply #7 on: October 08, 2016, 04:23:23 PM »
"A good battery makes a happy Guzzi owner!!!"   Words to live by.
Cheers, Tim
2008 BREVA 750
2020 V85TT ADV rosso
2016 APRILIA SHIVER 750
2013 VICTORY JUDGE CUSTOM
2013 VICTORY XR CLASSIC
2006 VICTORY V92TC
« Reply #8 on: October 08, 2016, 05:52:38 PM »
:thumb: :thumb:
I think you might have hit the nail on the head, I have no idea at what Voltage level that happens, perhaps you could experiment over the winter.
The fuel pump would still have primed because at that point the starter was not sucking the battery down or perhaps the ECU doesn't care about the Voltage at that point.
« Last Edit: October 08, 2016, 05:59:27 PM by Kiwi_Roy »
