My 2013 V7 stone started to make funny noises in the rear drive when I hit a bump or sudden movement. It felt like something was loose in the rear casing that would occasionally bump up and interfere with the drive gear. I drained the rear fluid and found it was silver with aluminium bits suspended in the oil. I took the final drive apart and found that two of the 8mm hex bolts that bolt the bevel gear to the hub had sheared off and the heads had been bouncing around inside the casing grinding the crap out of the aluminium shell. The other 4 were loose. What a disaster. The bike is 3 years old and has 25,000 km on it. It is fixable with a good cleaning and new bolts and gaskets but wow.Dave
This is the sole instance of this that I've ever encountered on a small block MG. My first guess is that the assembler's tool had the torque setting mis-dialed and the bolts were severely over-torqued, leading to their failure in use. But, that wouldn't explain why the other 4 bolts were loose. I don't know what MG's policy is about post-warranty-period coverage, but if you can convincingly show that your bevel box wasn't previously serviced, you might be able to make a claim.UPDATE: Uh Oh! Now I have to start being concerned (see second report by aiken, below). Not a good development.
