Author Topic: PHF 36mm Sort/Restore Tutorial  (Read 2339 times)
Offline Cal3
« on: October 12, 2016, 10:05:14 PM »
Hi,
Going thru LM III that has sat for years. In process of cleaning out fuel tank and will need to go thru the stock PHF36MM carbs. Anyone know of a good tutorial/tips for going thru these as far as what to watch for.
Thanx,
Clay
Re: PHF 36mm Sort/Restore Tutorial
« Reply #1 on: October 12, 2016, 10:10:42 PM »
 It might be worthwhile to search for old posts from Morrizi and Yak Fat . Same guy , unfortunately we lost him some time back . He seemed to truly understand those carbs .
 Just search Yak Fat , sorry .
« Last Edit: October 12, 2016, 10:14:09 PM by oldbike54 »
Offline Cal3
« Reply #2 on: October 12, 2016, 10:58:34 PM »
THANK YOU DUSTY !!
Online sdcr
« Reply #3 on: October 13, 2016, 05:28:55 AM »
Hi,
Thanx,
Clay
When I was recommissioning my 83 LM III, one of the float needles had an inconsistent habit of sticking closed. Might be worthwhile to replace these, along with all of the gaskets and O rings.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline Cal3
« Reply #4 on: October 13, 2016, 02:41:39 PM »
Thanx for tip!! :thumb:
Offline radguzzi
« Reply #5 on: October 13, 2016, 03:38:31 PM »
Do you have a copy of Guzziology...?
There are charts for the proper jets, needles, atomizers and slides to use etc.  depending on whether you have exhaust and air filter mods.
The teardown, cleaning is and assembly is really pretty straight forward.   I would leave the pumper bodies alone though.
Best,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
Offline Cal3
« Reply #6 on: October 13, 2016, 08:23:56 PM »
Thanx Rob.......I dont have a Guzziology.....if you only had one workshop manual, is it still the best one to have? I am going to take the optmistic approach that it was running good and set up properly before it sat. So round one will be to try and clean everything out, sync em, and record whats in em. After this I will try to get it right. The accelerator pumps are the part I know the least about. I am hoping that it hasnt been messed with much, it is all stock including airbox and exhaust. This bike came from a museum and is in very nice original condition.
Offline SED
« Reply #7 on: October 13, 2016, 09:08:20 PM »
Carb specs are here:  (see PHF36BD+BS and DD+DS but no MM)
http://www.thisoldtractor.com/dellorto_carburetor_specifications_for_moto_guzzi_motorcycles_--.html
Greg Bender comes through again!
Here is a link to a PHM manual that should work for a PHF manual.
guzzitek.org/documents/carburateur/Dell%20Orto%20Atelier.pdf
You can clamp the carbs in a vice side by side and push the levers together to make sure the accel pumps are squirting the same (adjustment changes the squirt time).
Previous owner installed pod filters and it's been a pain to get it to run right.  Apparently the stock airbox is well designed to tune the intake (Greg Field's book) so leave it unless there is a problem.  Mine now has the "Gruner punkt" settings in the table (except the idle jet is 60 for the pods), but the timing advance springs had to be replaced before it ran right.  It may still get poor gas mileage...
Old slides had worn through the hard plating on them - replacing them improved idle smoothness.
Cheers!
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Offline Cal3
« Reply #8 on: October 13, 2016, 11:52:37 PM »
Thanx SED....those tips and the links will be helpful.
Regards,
Clay
